10-23-2021, 11:13 AM | #1 |
6 blade plastic radiator fan
Hello, I just received "mikes-afordable" 6 blade plastic fan with fan belt, water pump fan mounting set and fan knock off tool for my 1931 model a. I'll be replacing the 4 blade metal fan that lost a blade. The installation appears to be straight forward however, I've never done this before so I wanted to ask if anyone has any tips or words of wisdom regarding the installation. Many thanks.
10-23-2021, 11:50 AM | #2 |
Re: 6 blade plastic radiator fan
Does it have a metal hub, or a plastic hub?
10-23-2021, 12:19 PM | #3 |
Looks like metal in the photo: https://www.mikes-afordable.com/product/A8600P.html
10-23-2021, 01:02 PM | #4 |
it has a metal hub
10-23-2021, 01:19 PM | #5 |
The only thing(s) I would say is read the directions. And recheck the tightness of the fan after using the car a little. They tend to losen up for some reason.
I took my 4-blade off, and went to the plastic one like this, and I love the piece of mind it gives me. Check to see of it rattles on the housing of your waterpump. I filed my edge down just a bit, but don't get crazy with it. That edge has a lot of stength in it. I added a couple of gaskets under my housing to get the alignment right. |
10-23-2021, 03:28 PM | #6 |
10-23-2021, 03:42 PM | #7 |
Like to see reviews of this plastic fan after its been in service for awhile. If the six blade plastic fan moves more air then it interests me. My two blade aluminum fan does not track well and its an added souce of vibration.
10-23-2021, 04:31 PM | #8 |
Also an impending disaster when it comes apart.
10-23-2021, 04:56 PM | #9 |
10-23-2021, 05:02 PM | #10 |
I've never heard of an aluminium 2 blade fan coming apart. I have been running one of those plastic ones for about 50-55,000 miles now without issue.
10-23-2021, 05:04 PM | #11 |
Plastic fan.
Some time ago when I was having cooling problems I put a plastic fan in my Tourer. From a Toyota, I think it was a Corolla. It didn’t make a great deal of difference and I later found it was the radiator that needed replacing and not the fan. Never the less I later purchased a plastic fan from Snyder’s and found it to be the same- I think in all respects. Because the plastic blades are shorter and it weighs less it should take slightly less power to drive it. In addition it will not lose a fan blade like the old metal blades. I am not pedantic about keeping the systems strictly original.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. Last edited by woofa.express; 10-24-2021 at 11:53 PM. |
10-23-2021, 05:21 PM | #12 |
17 plus years on my 6 blade plastic.
10-23-2021, 07:05 PM | #13 |
I have over 20,000 miles on my plastic fan, still going strong.
10-23-2021, 09:09 PM | #14 |
I know of three two blade fans that came apart, took out the radiator and made a mess of the hoods. I don't know if these were aluminum or steel. If this isn't an issue with aluminum fans, I stand corrected. My car has a four blade steel fan. I also know of one of those that came apart. These need to be checked for cracks as well as the two blade.
10-24-2021, 05:06 AM | #15 |
The only fans that come apart are the original steel ones that are several pieces and will crack. The reproduction aluminum ones are cast and are almost impossible to break.
"The more things change, the more they stay the same." |
10-24-2021, 08:44 AM | #16 |
I have been running one since Dave Wilton brought it to market many years ago. No issues.
Bob Bidonde |
10-24-2021, 09:21 AM | #17 |
I might add, that when I bought mine they were heck of a lot cheaper.
10-25-2021, 10:33 AM | #18 |
Does the 6 blade really cool better, or are you installing them for piece of mind vs the 2 blade aluminum?
10-25-2021, 10:52 AM | #19 |
Could you please explain this.
10-25-2021, 01:44 PM | #20 |
I have a 4 bladed plastic fan, I believe you get more air movement from a four bladed as opposed to a six blade. I have a fair amount of time flying prop aircraft I believe a four bladed prop is more efficient.
JMHO not trying to start anything. |
Thread Tools | |
Display Modes | |
