08-09-2020, 09:44 PM | #1 |
Shift Lever Drawing
Does anyone have a measured drawing of the lower section of the shift lever? I have a machinist rebuilding one to original specs.
08-09-2020, 10:26 PM | #2 |
Re: Shift Lever Drawing
The original shift levers were made from one piece and bent to the correct angle. There were two angles, one for 28-29 cars, and one for 30-31 cars. The repos are all bent to one angle that is in the middle to fit all. They are also made of two pieces that are screwed together and welded just below the bend. Many have failed by either breaking at the weld or unscrewing. See the attached article.
All the originals can be repaired by welding up the worn 1\2" ball on the end of the shifter and grinding it down to fit the slots in the forks. The problem is having it re-plated. Very difficult in the the US due to environmental concerns. Tom Endy |
08-10-2020, 06:16 AM | #3 |
I have an original that was replated butler nickel and looks beautiful from the bell up. The problem is the plater told me he could weld up and grind down the ball to the correct size before plating. Well...he did build up and grind but instead of a ball it ended up a heavily nickel plated egg shaped blob. The machine shop at a nearby AFB will precision rebuild but needs a drawing for the CNC. The shifter forks are already done. If possible, I'd prefer not starting over with another lever and would like to get in done locally.
Thanks Last edited by dmaxweb; 08-10-2020 at 06:27 AM. |
08-10-2020, 06:34 AM | #4 | |
08-10-2020, 06:39 AM | #5 | |
08-10-2020, 06:48 AM | #6 |
08-10-2020, 06:53 AM | #7 |
Dmax,
I did that too and tried. The extremely worn ball is newly build-up welded. Then sanded and filed a spherical shape. But that didn't get exactly round. +/- 1/100 inch. Also the height of the sphere could not be reconstructed exactly because I could no longer recognize the original dimensions. Shifting was a bit scratchy. Therefore I installed a new gear lever.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
08-10-2020, 06:58 AM | #8 |
08-10-2020, 07:02 AM | #9 | |
Brent,
Or is that a misprint and should be 0.005 inches?
08-10-2020, 07:26 AM | #10 | |
Not a misprint. The size of the ball is not machined to 0.500" or ½". I think where some people started that misinformation (-besides reading it in Fordbarn and then telling it to others. ) is that someone likely said file your shifter forks to straighten them up, and then just make the ball oversize to something such as ½ inch to compensate. Before long the shifting becomes difficult as it passes thru the neutral position due to the oversized ball. |
08-10-2020, 08:49 AM | #11 |
The gearshift lever needs some protection against human contact. I find that when wearing short pants my leg often touches the lever, so the nickle plating eventually corrodes. Same goes for the chrome plated repro lever. To preserve your shift lever, slide a piece of clear plastic tubing over it.
Bob Bidonde |
08-10-2020, 09:53 AM | #12 | |
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 08-10-2020 at 05:12 PM. |
08-10-2020, 10:21 AM | #13 | |
08-10-2020, 10:58 AM | #14 |
08-10-2020, 05:09 PM | #15 |
08-11-2020, 09:18 AM | #16 |
08-11-2020, 10:17 AM | #17 |
This one?
08-11-2020, 10:44 AM | #18 |
08-11-2020, 10:58 AM | #19 | |
And Yes, that is my drawing of the Fork. |
08-11-2020, 11:00 AM | #20 |
Thread Tools | |
Display Modes | |
