01-30-2020, 12:55 PM | #1 |
Garage heat
It's mid 30's here, in the 20's in my garage...I'm freezing
How do you keep your garage warm?
01-30-2020, 01:19 PM | #2 |
Re: Garage heat
Wood stove
Pluck |
01-30-2020, 01:24 PM | #3 |
Re: Garage heat
oil-filled space/radiator heaters
01-30-2020, 01:31 PM | #4 |
Re: Garage heat
60,000 btu nat gas fired furnace suspended from the 10 ft ceiling. It is 40 degrees outside this morning and 73 degrees in the shop. i am a happy camper today. ken
01-30-2020, 01:32 PM | #5 |
Re: Garage heat
Move to South Florida??
01-30-2020, 01:42 PM | #6 |
Re: Garage heat
01-30-2020, 01:53 PM | #7 |
Re: Garage heat
Ponderosa Pine chucked into my wood stove. Heats me several times... when I cut it, load it, split it, stack it and burn it.
01-30-2020, 02:41 PM | #8 |
Re: Garage heat
The old potbellied wood stove from my youth.
The one that was used everyday from fall until spring. The kitchen range only when it got cold and the big red monster in the living room only on Saturday nights and some Sundays. |
01-30-2020, 02:59 PM | #9 |
Re: Garage heat
100,000 btu gas heater,direct vent through the wall,toasty!
01-30-2020, 03:13 PM | #10 |
Re: Garage heat
Hi,
I use infrared heater and warm air.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
01-30-2020, 04:13 PM | #11 |
Re: Garage heat
Heat in the garage is why I won't be doing anything today. It will be in the low 40s and likely more in the workshop so I'll stay where I can breathe. BTW, low 40s is about 110F.
Heat in the garage! I'm happy to share. It'll be another shocker for the fires which are still burning. It's been over 3 months now. GIVE US A BREAK!
01-30-2020, 04:18 PM | #12 |
Re: Garage heat
Mini split heat pump. Works great!
Corley ----------------- Subscribed to the KISS principle! |
01-30-2020, 04:47 PM | #13 |
Re: Garage heat
All electric house, so have a 220 volt 5000 watt electric heater.
01-30-2020, 04:53 PM | #14 |
Re: Garage heat
Well insulated garage, portable kerosene heater... does the job in New York's Hudson Valley.
01-30-2020, 04:59 PM | #15 |
Re: Garage heat
2020-01-30_04-51-05 by Kerry Grubb, on Flickr
2020-01-30_04-51-05 by Kerry Grubb, on Flickr 2020-01-30_04-52-46 by Kerry Grubb, on Flickr I have this in my garage. Propane. Been in place for 3 years now and I havent got to getting it hooked up. I never think about it until winter, then the gas guy gets too busy to do the job. I have an old oil burner that I took out of my house and was thinking about putting that in my large shop. Maybe i'll have heat in both places next winter. |
01-30-2020, 05:46 PM | #16 |
Re: Garage heat
Open flame heat in a building full of gas fumes? Sounds scary to me. My new garage is going to have radiant heat in the floor. My current garage is well insulated and warms up nicely from the florescent lighting.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-30-2020, 06:07 PM | #17 |
Re: Garage heat
I’m in north Georgia. So far our winter has been pretty mild. My garage/workshop is in the “walk out” basement of our house. A wall mounted propane heater keeps it very comfortable.
01-30-2020, 06:20 PM | #18 |
Re: Garage heat
I use a air conditioner, heat pump in the garage wall. It works great in sumer or winter.
01-30-2020, 07:18 PM | #19 |
Re: Garage heat
Hey burner31, I live in New Jersey so our winters are long and cold like yours. When this house was built I put in two 10 foot electric baseboards in the garage and when it's 30 degrees outside I can be comfortable at 60-65 in the garage, but I have to be proactive about my garage time and give the place a chance to warm up for a few hours before it gets cozy. I like the electric heat because it's does not require me to burn something or deal with the ignition problem of solvents if I was burning something for heat. Yes the electric meter spins when I turn on the heat but wood pellets and kerosene cost money too and then there is the maintenance issue.
01-30-2020, 08:06 PM | #20 |
Re: Garage heat
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
Thread Tools | |
Display Modes | |
