04-16-2019, 04:20 PM | #1 |
Bendix bolt retrieval
Trevor lost a bendix bolt on our South Island rally in Te Anau. I had read on Fordbarn varoius retrieval methods. All we had was an old vacuum cleaner and my syphon hose. It caught the bolt end-on so easily I could not believe it!
SAJ in NZ |
04-16-2019, 09:24 PM | #2 |
Re: Bendix bolt retrieval
So you fed the siphon/vacuum hose through the starter opening and down into the flywheel housing to retrieve the bolt?
04-16-2019, 10:12 PM | #3 |
Trevor needs to buy lottery tickets
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
04-16-2019, 11:22 PM | #4 |
Hadn’t thought of doing it that way!
04-16-2019, 11:44 PM | #5 |
You carry a siphon hose?
W. Michael |
04-17-2019, 04:19 AM | #6 |
And yes we just fed it down through the hole where the starter goes and it picked it up immediately. We could not find a tab washer though. Maybe that is why the bolt came loose. SAJ in NZ |
04-17-2019, 07:29 AM | #7 |
You'll find the tab washer in a gob of grease attached to your starter pinion broken tooth where it got transferred by the flywheel ring gear.
Well, thats where I find my ANYTHING - or similar location/circumstance performed by equally happenstance occurrence. There is a Murphy Corollary at work here somehow. http://www.murphys-laws.com/murphy/murphy-laws.html Joe K
Shudda kept the horse. |
Thread Tools | |
Display Modes | |
