06-20-2017, 11:21 AM | #1 |
Carb throttle not fully openning.
With my foot pressed hard to the floor there is still a bit to go at the carb end.
What can be done to achieve full throttle ? |
06-20-2017, 11:32 AM | #2 |
Re: Carb throttle not fully openning.
Simply bend the throttle linkage to get maximum throw. Bend it slow and cold.
It could be someone installed the engine with the linkage installed and bent it against the firewall. Easy peasy
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
06-20-2017, 12:18 PM | #3 |
Listen to the RawhideKid. He knows what he's talking about! Jeff
Let's let pylons, be pylons! |
06-20-2017, 12:48 PM | #4 |
It can be wear too.
06-20-2017, 01:49 PM | #5 |
Hey, thanks for the picture.
See where the arrow points? That is the easiest place to bend to fit. Won't hurt a thing to give it a little bend.
06-20-2017, 01:49 PM | #6 |
Tom Endy |
06-20-2017, 05:17 PM | #7 |
That's exactly what I was thinking earlier today Tom Endy. Im see surprised no one has sold that rod that goes to the carb with an adjustable section in the middle
06-20-2017, 05:30 PM | #8 |
Question does it go full throttle with the hand lever? If not then I have bent the arm in the picture with the arrow point to it. I slipped a box wrench over it and bent a little in several places.
06-22-2017, 02:18 PM | #9 |
Those throttle assemblies get bent during engine removal an installation when they aren't removed.
06-25-2017, 05:17 PM | #10 |
I gave the arm a slight bend with an old box wrench and its done the trick,
Thread Tools | |
Display Modes | |
