08-27-2013, 09:54 AM | #1 |
U Joint Problem Diagnosis
Anyone with a good method of diagnosing a U joint fault on a model B? I suspect the U joint based on what I think is excessive vibration at higher speeds (above 35 -40 MPH) . The car has 70k miles, and I think its still the original.
Al |
08-27-2013, 10:05 AM | #2 |
Re: U Joint Problem Diagnosis
Try driving at 45 and gently work the gas pedal between accelerate and coast . If it is the u-joint the transition from power to coast and back should make the vibration and or noise change . MANY u-joints are shot due to improper lube or no lube at all .
08-27-2013, 08:14 PM | #3 |
Try putting a full tube of low melt chassis grease in the U joint. I have heard them like you described and work good with no noise or problems for years latter. It's worth a try. G.M.
www.fordcollector.com |
08-28-2013, 03:18 PM | #4 |
I took a clamshell and added a zerk fitting to the bottom. Filled it until it came out the top "fitting hole" and then plugged the hole with a pipe plug.g
08-28-2013, 08:39 PM | #5 |
Use Cornhead grease and see if this quiets the uni. It did mine.
08-28-2013, 09:41 PM | #6 |
In any case just squirting some more lube in the hole wont make the problem go away so before you really break down with a siezed upper driveshaft bearing you are going to have to spend a little time trouble shooting.
dickspadaro.com |
Thread Tools | |
Display Modes | |
