Old 12-10-2014, 10:27 AM   #1
ODFever
ODFever's Avatar
Default Bratton’s 19” Metal Stem Tube vs Rubber Stem Tube
I am very close to purchasing my first Model A from a friend. The current owner told me the car needs 6 new tires, and it might need new tubes. In my research, I discovered that most of the tubes produced today are junk. The current owner keeps 2 spare tubes with him at all times, and has replaced failed tubes on the side of the road. He said the tubes split at the base of the stem. This is a major concern for me as I live in the city and have absolutely no desire to end up with a flat because of a failed tube. I don’t plan on ever having the car Blue Ribbon judged. I am concerned about safety.
I read on a previous thread that Bratton’s tubes are higher quality. Is it worth the extra expense for the metal stem tubes? Are they better than the rubber stem tubes? Are there other suppliers of high quality tubes? I’m open for suggestions.
Thanks!
ODFever is offline   Reply With Quote
Old 12-10-2014, 10:29 AM   #2
Mitch//pa
Default Re: Bratton’s 19” Metal Stem Tube vs Rubber Stem Tube
its worth the extra money to buy the Brattons tubes
Old 12-10-2014, 10:52 AM   #3
diomed
diomed's Avatar
Brattons sells 2 types of tubes, metal stem and rubber stem
kris
diomed is offline   Reply With Quote
Old 12-10-2014, 11:27 AM   #4
MikeK
MikeK's Avatar
Originally Posted by ODFever View Post
. . .I don’t plan on ever having the car Blue Ribbon judged. . . I read on a previous thread that Bratton’s tubes are higher quality. Is it worth the extra expense for the metal stem tubes? Are they better than the rubber stem tubes? Are there other suppliers of high quality tubes? I’m open for suggestions. [/COLOR][/SIZE]
Today the metal stem tubes are simply the rubber stem tubes with the stem cut out and replaced with the metal stem assembly. They are not manufactured as a separate item. The reliability of metal stems is dependent on the skill of the person that installed them in the tubes. Changing a metal stem tube on the side of the road is a little bit more complicated as you have to unscrew the long locking nut holding the stem to the rim. Use the Bratton's rubber stem tubes. If/when you ever decide that you want the look of the metal stems you can remove the rubber stems from the tubes you have. You can buy and install just the metal stems in any tube.
Side note- If you plan to use balance beads it is easier to install them with the tubes in hand on a workbench.
MikeK is offline   Reply With Quote
Old 12-10-2014, 11:34 AM   #5
Scott Hall
Scott Hall's Avatar
I have replaced 9 tires and tubes with rubber stems (5 on my fordor and 4 on my Tudor) they were all purchesed from Coker tire and I have not had any failures in three years of use.
Scott Hall is offline   Reply With Quote
Old 12-10-2014, 11:48 AM   #6
Steve Wastler
Steve Wastler's Avatar
Brattons metal stem tubes are are not the clamp in style metal stem as stated above. They are manufacturer made vulcanized in metal stems.
Steve Wastler is offline   Reply With Quote
Old 12-10-2014, 11:52 AM   #7
jkeesey
jkeesey's Avatar
I have always used rubber stem tubes from Universal Tire. Never had a failure and Ive installed dozens.
jkeesey is offline   Reply With Quote
Old 12-10-2014, 11:58 AM   #8
Mitch//pa
that is correct i just bought a set
Old 12-10-2014, 12:01 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
I've always used rubber stem tubes because they are much easier to work with .
Old 12-10-2014, 02:05 PM   #10
Brother Hesekiel
Brother Hesekiel's Avatar
I have a 1963 Lambretta scooter that was a virgin when I bought it, having sat 49 years in a blacksmith shop. I bought new tires and tubes for it since I drive/ride everything I own, and one of the new tubes was faulty, so I put the old Italian Ceat tube from 1963 back in. It's still in there, leak free.
When I bought new tires and tubes for my Model A, I paid extra for the Brattons tubes, following the recommendations on this board. One of the five was faulty, so I had to order one from Lucas in Long Beach. Informed Brattons but they didn't give a rat's behind, so that was the first and last time I ordered anything there.
How often do you have a flat with your modern car? I drive about a 100 different cars per year, and I haven't had a flat on any car as long as I can think back, until last Sunday when the right front of the 1961 Jaguar I was driving was flat. I will probably not be on this Earth anymore by the time the new tube we installed yesterday goes flat again. I think you worry way too much about this. All modern cars have rubber stem tubes now, and if they were prone to early failure, that would not be the case.
Brother Hesekiel is offline   Reply With Quote
Old 12-10-2014, 02:16 PM   #11
super flat
super flat's Avatar
I don't know what you are driving for new cars but every newer car I have is tubeless only. Gary
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 12-10-2014, 02:20 PM   #12
newshirt
newshirt's Avatar
Metal stems add to the old-timey look of your car.
I once had a guy point down and ask, "What are those?" He was so surprised by those odd looking metal things that he could not get it out of his head. He didn't think they were valve stems, and just had to ask.
Ray White
newshirt is offline   Reply With Quote
Old 12-10-2014, 02:46 PM   #13
LopezCarguy
LopezCarguy's Avatar
I just installed five tubes (metal stems) and tires a short time ago from Coker and have not had a once of trouble, nice people to deal with..even have the metal covers from coker to be authentic
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
Old 12-10-2014, 02:52 PM   #14
portside
Next time you are on a NEW car lot check and see how many new cars have metal valve stems.
portside is offline   Reply With Quote
Old 12-10-2014, 03:55 PM   #15
jkeesey
jkeesey's Avatar
1 ton trucks do. I just got a tahoe with metal stems.
Old 12-10-2014, 04:46 PM   #16
CarlG
CarlG's Avatar
Even though they are tubeless, they still have rubber stems. Years ago I could specify metal stems even on tubeless tires, but haven't seen any in a while.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-10-2014, 06:28 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
My 1950 Studebaker has tubeless radial tires and steel stems in stock rims.
Many aluminum rims come with steel stems.
Old 12-10-2014, 06:37 PM   #18
Mitch//pa
Tom
Are they bolt in stems or metal stem with rubber a rubber pull through base
Old 12-10-2014, 07:03 PM   #19
Tom Wesenberg
Tom
They are bolt in stems. I also saved a couple sets when I worked at the junk yard. The guy that restored the Stude 20 years ago installed the steel stems and radial tires.
Old 12-10-2014, 08:59 PM   #20
montanafordman
montanafordman's Avatar
I went with the Brattons metal stem tubes a few years ago and have not had any problems. I have not even had to add any air in that time frame.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
