Old 09-14-2014, 09:54 PM   #21
41ford1
41ford1's Avatar
Default Re: Sympathy pains for Old Henry
Originally Posted by JM 35 Sedan View Post
Is the bore over or the piston under in No. 1 cylinder? What does the cylinder wall finish look like in No. 1? How is the fitup of rod bushings to piston pins and pins in pistons? The bearings and journals on crankshaft do look nice in your pictures.
John, This block was bored .060 over. It is effectively a 223" in a 215" disguise. All the cylinders are looking good. Such that I would just break the glaze. Rod pin bushings and pins are something I need to take a closer look at.
None seemed to have excessive movement.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 09-14-2014, 11:01 PM   #22
JM 35 Sedan
JM 35 Sedan's Avatar
I was trying to rationalize in my mind how No. 1 cylinder wound up with 0.022" clearance between piston and cylinder wall? If all cylinders are measuring correct diameter for +0.060 overbore how did that piston wear enough to give 0.022 clearance? Or did maybe that piston start out undersize from the begining? Just wondering.
John
Old 09-14-2014, 11:34 PM   #23
Tinker
Tinker's Avatar
I always consider 1 thousands at the bottom of the piston bore a decent runner. Hey If your looking for a set of nos barker high lifts for your exhaust rockers send me a pm.
Great wagon by the way.
Old 09-15-2014, 12:06 AM   #24
trainguy
trainguy's Avatar
Chuck are you measuring the piston across the skirts?.022 is way to much clearance !
trainguy is offline   Reply With Quote
Old 09-15-2014, 12:14 PM   #25
41ford1
41ford1's Avatar
At the skirt area. I somehow reset zero when I measured the pistons yesterday. Rechecked bores and pistons today. All is good. Rechecked the pin play. No 2 seems to be the source of the knock. The big end moves about 1/4".
As far as metal expansion rates, I do know this. That bit of info should have bubbled to the top when I was thinking of piston slap getting worse when hot.
Old 09-15-2014, 12:57 PM   #26
TomT/Williamsburg
TomT/Williamsburg's Avatar
Glad things seem to be a lot better than they might be, Chuck - you might make that time frame we spoke of! Keep at it .....
TomT/Williamsburg is offline   Reply With Quote
Old 09-15-2014, 03:20 PM   #27
Mart
Mart's Avatar
1/4"?? Wow. That's what's a knockin' all right.
Mart.
Old 09-16-2014, 02:15 AM   #28
trainguy
trainguy's Avatar
1/4"side play in just one rod,wow,how is that possible without major wear or bad machining on the crank cheeks..This engine ran fine for years.How much side play in the other rods.I understand what you are saying,it rocks side to side 1/4"! I think you have found the problem.
Old 09-16-2014, 05:45 AM   #29
George/Maine
George/Maine's Avatar
My guess the rod got bent when in stalling piston. If you had another engine for a piston and rod would get you going.
George/Maine is offline   Reply With Quote
Old 09-16-2014, 01:39 PM   #30
41ford1
41ford1's Avatar
Yup, if held at the center of the pin it rocks from side to side. The rod looks straight. The small rod end bushing is worn. The block, head, crank and the piston & rod assemblies are at the machine shop. This six is down for a complete rebuild. The condition of the head and rings dictate that it is time. Hopefully there are no fatal cracks that show up.
Old 09-22-2014, 04:06 PM   #31
41ford1
41ford1's Avatar
It is a bit surprising this engine ran as good as it did until the knock showed up. The head work is in progress. Hardened seats, valve guides are on the list for that. I found out today that the block needs a sleeve. One cylinder was cracked. When all is done it will be a 227".
Old 10-06-2014, 07:24 AM   #32
41ford1
41ford1's Avatar
Update:
The machine shop needed two weeks to do the work and get the required parts.
The crack in #3 was circumferential near the top of the cylinder. It was low enough to catch the top comp ring. That cylinder is getting a sleeve. I will know today if I can get it back this week.
In the mean time I cleaned the parts I have in prep for paint. Forum member Tinker sold me a set of Barker High lift rockers. Those are installed on the rocker shaft now.
Old 10-06-2014, 07:36 AM   #33
JM 35 Sedan
Thanks for keeping us posted Chuck. Sounds like progress is being made.
John
Old 10-11-2014, 07:41 PM   #34
41ford1
41ford1's Avatar
Got it back from machining. It's now is a 226" OHV. Started the reassemby process. This should be a great runner.
BTW. Ol Ron knows his stuff! Hastings rings break in procedure on the box. " Tune engine to manufacturers specifications. Test run vehicle at 35MPH and accelerate at full throttle to from 35 to 55MPH. Repeat at least 10 times avoiding kick down on automatic transmission equipped vehicles. Cars may be driven normally after this although sustained high speed should be avoided. Trucks and tractors should be broken in on light duty if possible. Avoid lugging engine."
Old 10-12-2014, 08:08 AM   #35
Cecil/WV
Cecil/WV's Avatar
That's the same instructions Hastings put out 45 years ago. Good to see your progress.
Cecil/WV is offline   Reply With Quote
Old 10-12-2014, 01:16 PM   #36
bobH
Hastings... 'rebore-on-the-run'. Some of us here are surely old enough to remember.
bobH is offline   Reply With Quote
Old 10-12-2014, 06:08 PM   #37
Old Henry
Old Henry's Avatar
41ford1, glad to see your progress. I'm just a step ahead of you. Just put the engine back in on Friday. Hope to have it back on the road tomorrow or the next day.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 10-16-2014, 05:25 PM   #38
41ford1
41ford1's Avatar
Finished the install today. Ran it long enough to warm it up. Set the timing and checked for leaks. It sounds good. Will do some break in runs tomorrow as it is raining hard today.
Old 10-16-2014, 05:39 PM   #39
Old Henry
Old Henry's Avatar
Hope yours ends up better than mine did. (See my sad story here: http://www.fordbarn.com/forum/showthread.php?t=152238)
Old 10-16-2014, 08:19 PM   #40
JM 35 Sedan
Looking very good Chuck!! You do nice work!!
John
