View Poll Results: Whats your favorite bore size using a 4 inch merc crankshaft
| stock just hone |
1 | 1.61% |
| 255-3.188 |
5 | 8.06% |
| 276-3.313 |
44 | 70.97% |
| 286-3.375 |
7 | 11.29% |
| other |
5 | 8.06% |
| Multiple Choice Poll. Voters: 62. You may not vote on this poll | |||
This is for a street rod,34 coupe, flathead 8BA bore size favorite !
+.030, .060, .080 or .125. Just wherever it will clean up.
It is determined more by block condition then your wishes/favorite size.
If you want to bore one from standard all the way out to max, you will lose a lot of potential use of the block. If you are already at 3 5/16" then that is a good size for a hot rod. A person can go to sleeves though and use larger if you have a mind to. It just depends on how much you want to spend and how long you want it to last.
I did my first a 3 5/16 (276 with a Merc crank) and it worked well. I just bought another set of 3 5/16 pistons (this time for a stock stroke). Pistons, rings, and pins were $100, which is a heck of a lot less than a merc crank (if you can find one) for a comparable increase in displacement.
255 is stock with a 4 inch crank.
Well I have a 51 merc eng(255 stock for now)for my Av8.May go a bit over in the future.
I like 276, 1/8'' bore. If you wear that bore out they make ,030 over 3-5/16 and probably .040 and .060 Walt
#11 | |
Egge makes light 3 ring piston in 3 5/16, + .020 and .030. With the thin Metric rings. Saved a 276 with the .020" and rings from a Volvo truck. I now have a 280 (279.4) Milled EAB heads 8.2CR and a stock EAB cam. Talk about torque??? I think even JWL would like it.
#13 |
I've got a 265 by my calculations, I just think, why bore it bigger than you have to, after all they aren't making them anymore.
#14 | |
Speedway's garage sale section. About a year ago thay had a lot of piston sets (some were advertized as being made by Offenhauser) on closeout. I posted it here and on the H.A.M.B. The pistons came in a "plain brown wrapper", so they may be Chinese. but I took a chance on them. They look real nice and I went over them with a mic and all appears well. We shall see. (Edit : Just for kicks, I checked the Garage Sale page again; there are still a few sets of pistons, but the prices I paid are long gone,) Last edited by tubman; 09-20-2014 at 02:12 AM. |
#15 |
#16 |
Speedway had some hypereutectic flathead pistons for a while that were cast for them. They must not have sold too well but I haven't really heard anything about how they worked out. It would be interesting to know. I always wondered why the piston makers didn't go that route. The expansion factors for those pistons allow for a tighter bore clearance than with forged ones. The cost might be prohibitive in a niche market. How strong they are would be the big question for me.
#17 |
Flathead bores are tougher than some of you give them credit for … part of the reason there still here.
The truth is you’d have a hard time wearing one to the point of needing a rebore in the time any of you have left. Bore it out all the way ... you cant take it with ya |
#18 |
The main question was WHAT IS YOUR FAVORITE BORE SIZE FOR A STREET ROD ...
#19 | |
?? all this talk about it, make me want to do it again, all I need is someone to make the "HOLE" And find me a pieeeekup 39 or 40 I'll do it........OLD.....BILL
#20 |
3 3/8
| Thread Tools | |
| Display Modes | |
