Old 09-14-2014, 03:52 PM   #1
Ronnie
Ronnie's Avatar
Default Re: Tell me this noise isn't what I'm afraid it is.
Originally Posted by Kube View Post
Balancing should at the very least be checked to see if it is necessary. Ford did a pretty darn good job on these engines when they were first assembled. the problem is most engines have had at least some work done on them since "day #1".
If I understand henry's post correctly, one cylinder was sleeved and the remaining seven were bored. Anyone that has good experience building engines knows this is a big no-no.
What is not good with one sleeve?
R
Ronnie is offline   Reply With Quote
Old 09-14-2014, 04:39 PM   #2
Old Henry
Old Henry's Avatar
I'm not sure exactly how it works but the same size of pistons went into all cylinders so I'm assuming that the one that needed the sleeve was bored slightly larger to fit the sleeve in. No problems now for 20,000 miles so far.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 09-14-2014, 07:06 PM   #3
Kube
Super Moderator
Kube's Avatar
If he bored that sleeved cylinder to match the others, that's a good thing.
I have seen engines wherein only one or two cylinders were sleeved and the bore(s) were not matched to the others.
Old 09-14-2014, 07:07 PM   #4
Kube
Super Moderator
Kube's Avatar
R
Not a thing as long as ALL the bores are of the same diameter.
Old 09-15-2014, 12:52 AM   #5
Mike B
I might be off base, but who would take and engine in to get rebuilt, and be told:
We need to sleeve a hole"
Okay...
Then the shop would order 7 pistons at ones size, and one at another?
Have you actually seen this?...I'd be extremely surprised...again...talking shop work, not when Bubba took it in and used what he had.
And realistically, what would a 1/2 cube of inches, and .01 of compression, affect the performance of an engine like a FH V8?
My personal opinion, is if I had a 60 over block and a standard sleeve size in a hole,,,no one could tell a bit of difference in a street build.
Mike B is offline   Reply With Quote
Old 09-15-2014, 07:52 AM   #6
Kube
Super Moderator
Kube's Avatar
Okay...
Actually this method is all too common. Even today engines rebuilt by Jasper, a very large corporation, does this as a matter of course. They go the "whatever is cheaper" method.
In a flathead it may not make a huge difference but it will make a difference.
I suppose it all boils down to doing a job correctly or doing it half a--ed.
Old 09-15-2014, 07:56 AM   #7
sidevalve8ba
sidevalve8ba's Avatar
Some mechanics are fast, others half-fast.
sidevalve8ba is offline   Reply With Quote
Old 09-15-2014, 09:01 AM   #8
40cpe
40cpe's Avatar
I would be more concerned about the imbalance created by different sized pistons. I don't think anyone who would bore just one hole would balance it.
Old 09-15-2014, 10:33 AM   #9
Mike B
I see your point, I suppose a large rebuilding house could save a buck or two per rebuild and over the course of time it would add up to some decent profit.
Sad thing.
