Old 09-07-2014, 08:39 PM   #1
Kahuna
Kahuna's Avatar
Default Fuel economy
Thought I'd share this with the group.
I just returned from a trip to Chester, CA., where a nice car show is held.
I started from my home in Brownsville, CA with a full tank of gas. The total round trip distance was 298 miles going from an elevation of about 2200 ft down to sea level, then up to an altitude of 4500 ft.
The car is a 32 Tudor sedan with an 288 CI flathead, Potvin 425 cam, 2 4bbl carbs, etc. Rear axle ratio is 4.11, but I have an overdrive that reduces the final drive to 3.21 (not used too much on the climb up, but used when possible).
Mileage on the way up was 16.9 mpg, with an overall of 18.1 mpg
Flatheads can be real good, I think
Thought I'd share
Jim
Kahuna is offline   Reply With Quote
Old 09-07-2014, 09:10 PM   #2
rlhinit
Default Re: Fuel economy
Let me get this right ! you have " 2 4bbl carbs ?? and you'regetting 18.1 mpg ??
rlhinit is offline   Reply With Quote
Old 09-07-2014, 09:16 PM   #3
JSeery
JSeery's Avatar
I did a double take on the 2 4bbl carbs regardless of the mpg!
Old 09-07-2014, 09:18 PM   #4
texas webb
Don't sound like a regret.
texas webb is offline   Reply With Quote
Old 09-07-2014, 10:05 PM   #5
Kahuna
Kahuna's Avatar
Yes, (2) four barrels, NO regrets
Old 09-07-2014, 11:21 PM   #6
Bassman/NZ
Bassman/NZ's Avatar
Me too! Don't recollect ever seeing a manifold for that....
Bassman/NZ is offline   Reply With Quote
Old 09-08-2014, 01:31 AM   #7
JeffB2
JeffB2's Avatar
Please post a picture of your flathead.
JeffB2 is offline   Reply With Quote
Old 09-08-2014, 01:52 AM   #8
scooder
That the one with two 4bbl teapots on him?
Martin.
scooder is offline   Reply With Quote
Old 09-08-2014, 02:25 AM   #9
51 MERC-CT
51 MERC-CT's Avatar
Unless it doesn't have secondary's they are really only two 2 bbl.'s probably 99% of the time.
Old 09-08-2014, 06:39 AM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I've talked to Jim, he has a beautifull set up there. I am running 276 with four 97's straight linkage T5 with 3:50 gears. Don't know what that finally ratio is in OD but at 60MPH with a GPS I'm turning 2000RPM. On secondary roads I get 18mpg. Walt
Old 09-08-2014, 08:11 AM   #11
Fordors
Two weeks ago, scroll to post no. 36-
http://www.fordbarn.com/forum/showth...118#post933118
The only set up like it in existence.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 09-08-2014, 08:12 AM   #12
Ol' Ron
Ol' Ron's Avatar
Having been working on improving the fues mileage of our flatheads, I've found that yo must start in the combustion chamber it's self. One reason you shouls try and keep the piston to head clearance very tight. Next the AF in cruise in the hi 14's low 15's, mid 13's in WOT. Followed by a good ignition curve, you need a fair amt of adv to burn a lean mixture. Last but not least is the basic design of the intake system allows the AF mixture to better vaporize before the plug fires. I like to run these engines in the 180 plus range. This is something that takes time and effort. However most people like to tell fish stories, it's the nature of the breed.
Old 09-08-2014, 08:42 AM   #13
JWL
I think about 18 MPG is the best I expect with my car.(276 and single 4 brl.) I have checked it several times. The 40 sedan, with Mitchell O.D. is heavy, with my load(3700), and it is not good from the aero viewpoint. However, there is much to be said about the driver when MPG is the focus. I am not a good MPG driver. I installed the MSD adjustable timing device and mounted the dial on my radio grille so I can adjust timing while driving. The crab distributor has limited capabilities when searching for a better "cruise" timing setting. Unfortunately I have not taken the car on extended road trips since installing the toy so cannot report on an improvements.
JWL is offline   Reply With Quote
Old 09-08-2014, 12:10 PM   #14
Kahuna
Kahuna's Avatar
JWL and everyone:
I expected far less than what I got.
I'm now thinking that on a regular road (not so hilly) that the
car will do 20, maybe more.
On the trip I described, speeds were 65 max, 45-55 normally.
Oh, not really hammering it, so no secondaries were used that I remember.
Yes, 51 merc is correct. It's just like running 2 Stromberg 48's until you
punch it
Old 09-08-2014, 12:55 PM   #15
Mart
Mart's Avatar
I'd say that's an excellent result and you obviously have the engine set up very well. Especially so considering the one off manifold and carb setup.
Mart.
Old 09-08-2014, 02:12 PM   #16
36tbird
Kahuna, I talked to Willie and he pulled the old VW trick on you where he snuck in 5 gallons of petrol in your tank at a stop on the way. Next part of the trick is to siphon off 5 gallons from your tank during your next day trip.
36tbird is offline   Reply With Quote
Old 09-08-2014, 02:25 PM   #17
37don
My Dad had a 65 Tbird and a guy asked him in sarcasm what he got for gas millage, his answer was "anything I want"! That being said I just got back from Lake George 506 round trip from Ri and got 18.2 mpg with a 276 in a 37 sdn. I have a Mitchel OD with final drive of 2.82. Engine built by who else but Ol'Ron.
Don
37don is offline   Reply With Quote
Old 09-08-2014, 03:45 PM   #18
Kahuna
Kahuna's Avatar
Good one, Lou
Don, you did great.
Flatheads are pretty good on gas
Old 09-08-2014, 04:54 PM   #19
hotcoupe
hotcoupe's Avatar
37don, what carburetor are you using, and what are the specs? if you please.
thanx, tom
hotcoupe is offline   Reply With Quote
Old 09-08-2014, 06:41 PM   #20
oldsman41
my 51 merc is stock 3spd od and i only get 18 i thought that was really good. guess i was wrong.
oldsman41 is offline   Reply With Quote
