#21 |
Thanks for all the advice. I'm going to scrap (cut a hole in) the old compressor tank and I'm just going to buy an inexpensive air compressor to take it's place. Franco
#22 |
A pressure vessel like we are discussing should be welded to add fittings. However it is only appropriate for a 'code' welder to do any welding on such a vessel. Be very careful with these tanks or vessels. All official testing is always done with liquid (water), as any crack or leak will quickly lower the contained pressure. Obviously that is not the case when they are gas (air) filled.
#23 |
I agree with the posters advocating an experienced certified welder do any mods to preesure vessels. However I wanted to add that in the 60's I had a Formula Ford Racing car whose entire tubular space frame chassis was nickle-bronze brazed together. It was hit broadside by at least two cars going 100+ MPH and the actual tube members failed,not one brazed joint failed. The car was repaired ,with braze, and survived another crash (driver error) with no failure of a brazed joint. Properly done a braze joint seems to be adequate . My experience. I would guess I would rather have TIG now.
#24 |
Recently there have been several new posters on Fordbarn, so I just mention this as a reminder that air compressors need to be drained on a regular basis. This means drain the water off the bottom, not drain all the air from the tank.
#25 |
Not my compressor, but 30 years ago I was airing up an old tire/tube that came on a 21" rim. Checked at 10 psi, 20 psi looked ok so I figured I would see if it would hold 35. I was about 32, when it blew. My neighbor and fathe came running from different directions. Shook the garage door and blew out a window. My hearing was messed up for about a day and the garage was filled with a black dust. I was dumbfounded it was such an explosion.
#26 |
I modify the drains ---my idea is if they are made easy to use the tank will be drained, I get rid of the old style winged petcock that is normally used, I extend the drain with a street elbow,a pipe long enough that a modern small ball valve with the easy to use lever is in a position that there is no crawling around and fighting to drain it----just lean over and turn the valve |
#27 | |
I would assume you could even use some type L copper pipe and plumb it from the bottom of the tank using a brass connector and run it up to a nice reach level, install valve and then run it back down to a bucket. Should still drain any fluid and would be really easy to open and close, no bending over! I guess I just showed how lazy I am. ![]() Thought I'd add this to the thread. Though its a water heater from the 1920s and not an air tank I feel they share the same dangerous in many ways.
#28 |
I work part time in a hardware store, where we purchased a used compressor for small engine service. The age of the compressor is unknown, but looked to be in good shape. I drained the tank after every use, but who knows what the previous owner did with it.
One day, I had it running and under pressure, when I heard leaking air. Yup, you guessed it, the tank was leaking. To say the least, it was shut down, and the pressure was bled off. The tank was disconnected from the compressor. Not having a spare tank lying around, and being on a tight budget, I improvised. Used an 8' length of 2" schedule 40 pipe and a few fittings for a receiver. Just moved the pressure switch, and relief valve over to the pipe and went from there. It does not have a lot of air capacity, but between the pipe and 50' of 3/8" air hose there is enough capacity there for our needs. There is enough air available to run an air ratchet and a small 40:1 chassis pump. Chris |
#29 |
Here is a water heater explosion film from years ago. Watts brought the original film to one of our plumbing contractor meetings years ago. Quite impressive! Also guys why don't you go see if you have a temperature and pressure relief valve on your water heater and scrap those old air compressors that are questionable. Hope the link works for you.
https://www.youtube.com/watch?v=5pVQryuKMj8 |
#30 |
Nice video!
#31 |
I would not go near any tank or vessel with either water, steam, air or what ever without a working SAFETY blow off. JMO
#32 |
I have two IR auto releases in my compressed air system, one at the bottom of the tank and the other about 50 feet away at the end of the long very slightly sloped pipe run that feeds all my service drops.
the tank drop has liquid all the time in the tray below. the other one not at all. |
#33 |
I had a Mexican taqueria owner, who believed in jerry rigging everything. Unfortunately he had no mechanical insight whatsoever. His water heater started popping off the relief valve, so he screwed in a 3/4" plug. Shortly thereafter, it blew. Went thru the attic, the roof, across kfc, across a 5 lane road, and landing in the middle of pizza huts parking lot. No one was injured. He moved up the street to a new location, because his building was toast. A year later, I went in to work on a fryer , and the fool had jumpered the hi temp limit. Oil will burst into flame at around 450/500 degrees.
#34 | |
#35 |
It was done in by the rust. The metal is very thin and jagged where it spit apart. The water that was in the tank sure made a big mess on his Cadillac and Harleys.
| Thread Tools | |
| Display Modes | |
