Old 08-28-2014, 08:33 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default S.t.p.
Is it S.T.P. that one uses in steering gear that is leaking??? Will S.T.P. leak, only more slowly, or will it not leak? Thanks
Old 08-28-2014, 08:53 PM   #2
Ronnie
Ronnie's Avatar
Default Re: S.t.p.
Isn't it corn head grease?
http://www.ntractorclub.com/howtos/p...d%20Grease.pdf
R
Ronnie is offline   Reply With Quote
Old 08-28-2014, 09:16 PM   #3
JT FORD
JT FORD's Avatar
Default Re: S.t.p.
I use the lube for Snapper lawnmower gear box. Thats the self-propelled walk behind ones. I comes in a tube and its pretty thick.
JT FORD is offline   Reply With Quote
Old 08-28-2014, 10:27 PM   #4
Bassman/NZ
Bassman/NZ's Avatar
Default Re: S.t.p.
I use Penrite Steering Box Lube. It's thick and stopped my leak.
Bassman/NZ is offline   Reply With Quote
Old 08-28-2014, 10:32 PM   #5
Bob G/Spanaway
Bob G/Spanaway's Avatar
Default Re: S.t.p.
I have used straight STP in a steering gear with good results.
It stopped a leak.
Bob G/Spanaway is offline   Reply With Quote
Old 08-28-2014, 10:41 PM   #6
36Bill
36Bill's Avatar
Default Re: S.t.p.
I use track and roller grease. It is like corn head grease, we just had it already. I tried stp and it just leaked out.
Bill
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 08-28-2014, 11:32 PM   #7
rheltzel
rheltzel's Avatar
Default Re: S.t.p.
I use a 50/50 mix of 140Wt. gear lube and STP. Pretty much stopped the leak; I usually add about a teaspoon of the mix every 2,000 miles.
rheltzel is offline   Reply With Quote
Old 08-29-2014, 12:50 AM   #8
Drbrown
Drbrown's Avatar
Default Re: S.t.p.
140w is standard for summer temps. Some use corn grease or add MMO or STP if leaking is occurring and/or to improve operation. Maybe time to rebuild the gear box ?
Drbrown is offline   Reply With Quote
Old 08-29-2014, 05:44 AM   #9
Vic Piano
Vic Piano's Avatar
Default Re: S.t.p.
I'm using STP in some steering gear boxes and Corn Head grease in others, have had good results with both. I've got all the component to rebuild the box in our '39 CS and I think I'll fill it with Corn Head grease.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-29-2014, 08:27 AM   #10
burly
burly's Avatar
Default Re: S.t.p.
It will depend on how severe the leak. STP will eventually leak out if the void is large enough.
burly is offline   Reply With Quote
Old 08-29-2014, 12:52 PM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Re: S.t.p.
Me too
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 08-29-2014, 01:01 PM   #12
32Gnu
32Gnu's Avatar
Default Re: S.t.p.
I used cornhead and it still keeps my frame from rusting.. maybe I should put a Zerk fitting and try the Snapper grease....
32Gnu is offline   Reply With Quote
Old 08-29-2014, 07:24 PM   #13
1931 flamingo
1931 flamingo's Avatar
Default Re: S.t.p.
PenRite is the way to go.
Paul in CT
Old 08-29-2014, 08:09 PM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: S.t.p.
I was using a 50/50 mix of gear oil and STP. That mix leaked out quickly. Then I switched to straight STP and that leaked out as well. I was about ready to pull the steering box to install seals and gaskets but decided to try John Deere Corn Head Grease and see how that would work. The JDCHG has been in there for over 15,000 miles now. Just a few drips show up occasionally on the pitman arm after a long hot run. The steering actually seems to be easier as well. Youz guyz can use what you please....I'm sticking with the "corny" grease
John
Old 08-29-2014, 10:12 PM   #15
fordman
Default Re: S.t.p.
OK, so we're talking about STP and I've heard the rumors what the S and T and P stands for but what have you heard it stands for?
I'm gonna compare my rumors with your rumors. 'been courious.......
fordman
fordman is offline   Reply With Quote
Old 08-29-2014, 10:27 PM   #16
Randy in ca
Randy in ca's Avatar
Default Re: S.t.p.
Scientifically Treated Petroleum
http://www.stp.com/faqs/general/
Randy in ca is offline   Reply With Quote
Old 08-29-2014, 11:06 PM   #17
Ronnie
Ronnie's Avatar
Default Re: S.t.p.
Sticks To Pistons "LOL"
R
Old 08-30-2014, 02:11 AM   #18
Mike B
Default Re: S.t.p.
Shut The Piehole
Mike B is offline   Reply With Quote
Old 08-30-2014, 03:48 AM   #19
Brian
Brian's Avatar
Default Re: S.t.p.
When I was a lad [a long time back], there were a lot of unplanned teenage pregnancies [many conceived in the back seat of a V8], and STP was infamously known as 'Support the Pill' True!!
Old 08-30-2014, 06:07 AM   #20
Jay in Mass
Default Re: S.t.p.
Since it comes in a tube, it should be easier to install. Is it something that most lawn mower repair places may have?
Jay in Mass is offline   Reply With Quote
