I'll offer a WAG... based on events as they happened on my own 47...
burned piston(s). I had problems with pre-ignition/pinging, and eventually found three pistons with holes on top, at edge, down into the ring-lands. With heads off, easy to see on top of pistons. Oh, the fun
#2 | |
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#3 | |
I had rebuilt it myself because it was seeping gas when I parked it in the garage at night and stinking up the garage. I also thought it might be part of the missing problem I had. After I rebuilt it, including replacing the power valve, it wouldn't hold gas after parked at night and I had to fill it with my electric pump every morning and choke it to start it. The engine didn't run any better either. So, I decided to put the Stromberg back in and see if it did any better.
I had Uncle Max rebuild my 97 but he left the .44 jets in thinking they were OK at my elevation of 5,000 feet. Maybe they were and that has nothing to do with anything but the plugs looked a little lean to me so I put bigger ones in. Didn't help the noise.
I just tried removing a spark plug to see if that made any difference, planning on removing one at a time to try to identify the offending piston. Unfortunately, the noise from the air rushing in and out of the spark plug hole drowned out all other sounds and I couldn't hear anything else.
Other ideas to identify the bad piston?
| Thread Tools | |
| Display Modes | |
