Old 08-11-2014, 01:41 PM   #1
39topless
Default adjusting 3 / 2's
Can't seem to find any tech support for adjusting (tuning) a 3 x 2 setup with three 97's. Any help would be appreciated.
Thanks, Phil
39topless is offline   Reply With Quote
Old 08-11-2014, 02:09 PM   #2
36tbird
Default Re: adjusting 3 / 2's
what kind of linkage, progressive or straight?
36tbird is offline   Reply With Quote
Old 08-11-2014, 05:46 PM   #3
39topless
Believe it would be classified as progressive. Pedal to middle carb, then linked to front and back carbs with one linkage. Should mention that it is running very rich.
Thank you
Old 08-11-2014, 06:43 PM   #4
Binx
You may find something here..
http://www.btc-bci.com/~billben/flathead.htm
Lonnie
Binx is offline   Reply With Quote
Old 08-11-2014, 07:39 PM   #5
Terry,OH
Terry,OH's Avatar
Progressive and the car runs on the center Carb. until you depress the pedal enough to start to open the front and rear (dumper) Carbs. The dumpers do not use their idle circuits. Straight linkage and all three Carbs work at the same time (from idle to full throttle) I would recommend the progressive IMHO. Check out the Stromberg web site (tech center) and if you can not find an answer to your questions contact Uncle Max.
Old 08-11-2014, 08:35 PM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Theres a group on the hamb board of carb questions set ups etc , most are 94 carbs but set up theory is the same . I have used this groups postings many times , some of them have it figured out...
http://www.jalopyjournal.com/forum/s...-94-group.232/
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-12-2014, 08:18 AM   #7
36tbird
Phil, you are right to address this issue. I had a friend who ran 3x2 with straight linkage. It ran very rich to the point that it carboned up the valve seats excessively. Finally one valve top broke off due to the carbon build up and the now loose valve top destroyed the valve seat area as it careened around in there. Block was a total loss.
Old 08-12-2014, 08:31 AM   #8
flathead4rd
flathead4rd's Avatar
Depends on on what engine modifications you have . More info needed. I run three 97's with straight linkage and have no problems.
flathead4rd is offline   Reply With Quote
Old 08-12-2014, 08:50 AM   #9
V8 Bob
V8 Bob's Avatar
I, along with many others, have been running straight linkage with 3 97s for many years and thousands of miles, with no problems or ill effects. The carbs have to be built and jetted properly, usually with #43 mains and # 69 power valves, along with careful synchronization. The result is very crisp throttle response and decent (20 mpg) highway millage. Intake manifold design and manufacture can vary in performance, but the Navarro I'm using works great with straight linkage. The only negative may be slightly worse city stop/go millage v.s. running progressive linkage.
Old 08-12-2014, 10:55 AM   #10
uncle max
uncle max's Avatar
... A page from my book!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 08-12-2014, 11:36 AM   #11
39topless
Wow, you guys are great. Lots of really good info. The only other engine mods are finned heads and remote coil. Right now I have to remove and clean the spark plugs about every 100 miles. Maybe I can make the adjustments and lean it down. Thanks so much.
Phil
Old 08-12-2014, 12:11 PM   #12
39topless
Wow1 Thanks for the warning. I'll try to get this leaned up before driving it much.
Phil
Old 08-12-2014, 12:18 PM   #13
39topless
The ultimate compliment!!!!
Old 08-12-2014, 12:53 PM   #14
36tbird
Yo Max, I do run my 2 Uncle Max 81's straight.
Old 08-12-2014, 02:19 PM   #15
my4dv8
You can not really run 2x2 successfully any other way than straight.
my4dv8 is offline   Reply With Quote
Old 08-12-2014, 05:04 PM   #16
36tbird
Uh yeah, hence the "wink".
Old 08-13-2014, 08:09 AM   #17
V8 Bob
V8 Bob's Avatar
I agree....thanks Max. Oh, and my 97s came from Uncle max.
Old 08-13-2014, 08:39 AM   #18
Bruce Lancaster
The Carbfather speaks! Now, about that book...
Old 08-17-2014, 03:43 PM   #19
39topless
I've learned a lot from the sources suggested by you all. Thanks again. I turned the jets down on the middle carb to a very lean setting and cleaned the spark plugs. Drove about a mile to the store, returned home and removed a plug. Found it to be completely black with carbon (after 1 mile!). Would there be any advantage to disconnecting the two dumper carbs and just work with the middle one until I get the thing running right and then reconnect the dumpers? Sorry for my ignorance but this is my first three carb setup.
Old 08-17-2014, 03:51 PM   #20
scooder
When you said "I turned the jets down on the middle carb to a very lean setting" you talking about the idle mixture screws on the base of the carb?
This does not affect the main jets, these are different, and unless you have adjustable main jets, and your actually adjusting these.
What you adjusting?
Martin.
scooder is offline   Reply With Quote
