Old 07-22-2014, 10:20 PM   #21
Willie Krash
Willie Krash's Avatar
Default Re: Kerosene and Gas?
Sorry my instruction were lacking. Regardless of the speed of the water I'd think the radiator is a heat exchanger. Has a long talk re this with a very bright fellow. I came to agree to fast is an old adage.
Here ya go Tom. It's in my mail program under notes, see how little I know about computers...
Alt + 0153..... ™... trademark symbol
Alt + 0169.... ©.... copyright symbol
Alt + 0174..... ®....registered * trademark symbol
Alt + 0176 ...°......degree symbol
Alt + 0177 ...±....plus-or *-minus sign
Alt + 0182 ...¶.....paragr*aph mark
Alt + 0190 ...¾....fractio*n, three-fourths
Alt + 0215 ....×.....multi*plication sign
Alt + 0162...¢....the * cent sign
Alt + 0161.....¡..... *.upside down exclamation point
Alt + 0191.....¿..... *upside down question mark
Alt + 1.......☺....smiley face
Alt + 2 ......☻.....black smiley face
Alt + 15.....☼.....sun
Alt + 12......♀.....female sign
Alt + 11.....♂......m*ale sign
Alt + 6.......♠.....spade
Alt + 5.......♣...... *Club
Alt + 3.......♥...... *Heart
Alt + 4.......♦...... *Diamond
Alt + 13......♪.....e*ighth note
Alt + 14......♫...... *beamed eighth note
Alt + 8721.... ∑.... N-ary summation (auto sum)
Alt + 251.....√.....square root check mark
Alt + 8236.....∞..... *infinity
Alt + 24.......↑..... *up arrow
Alt + 25......↓...... *down arrow
Alt + 26.....→.....r*ght arrow
Alt + 27......←.....l*eft arrow
Alt + 18.....↕......u*p/down arrow
Alt + 29......↔...lef*t right arrow
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 07-22-2014, 10:35 PM   #22
Tinker
Tinker's Avatar
Originally Posted by Old182 View Post
Kerosine, or K1, is a middle distillate and has an end boiling point (~550*F) between gasoline (437*F) and diesel fuel (640*F). Essentially, kerosene is jet fuel (Jet A) and becasue it's nearly all straight-chain paraffin, it has no real octane number and will lower the octane rating of your fuel by roughly the volume amount you add to your tank. I've heard in the 1930s farmers would start their Model A trucks on gasoline and then fill them with kerosene to run the rest of the day (hauling vegetables and fruit from the Hudson Valley to New York City). But with an end point of ~550*F, it's doubtfull it will completely combust leading to oil dilution and washing of the cylinder walls and carbon buildup in the ring areas. Personally, I wouldn't put kerosene in my tank (but then, I don't use MMO either).
Messing with hit and miss engines that can be run on kerosene. The octane level (cetane rating) is around 30 or less, compared to modern octane of 80-90. Now you will have to get the engine hot to run it. You might have to add water, what??? To keep it from detonating, but it is a cleaner fuel with Not as many additives. Not a good solution for a what your asking.
http://www.smokstak.com/library/tech...ine-engine-23/
Old 07-22-2014, 10:55 PM   #23
Brobrian
Brobrian's Avatar
Originally Posted by mshmodela View Post
0 C = 212° F on a Macbook it's [shift]+[option]+8
You see, you learn valuable stuff here all the time. Very helpful.
Forty horses is plenty.
Brobrian is offline   Reply With Quote
Old 07-23-2014, 12:21 AM   #24
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Veger, if your timing is advanced that much, then you are taking a big chance on beating your Babbitt out. We had a engine with low milage, at the repair facility for the 2014 mafca meet last week, and that's exactly what happened.
Old 07-23-2014, 12:43 AM   #25
Tom Wesenberg
Tom Wesenberg's Avatar
Did you mean 100 C = 212 F?
Old 07-23-2014, 08:00 AM   #26
Veger
Veger's Avatar
Originally Posted by charles in east texas View Post
I like your 29 Town Sedan. Is it a Briggs?
I have an unrestored Murray 29 Town Sedan.
Charles
Good day Yual!
Its a 29 Four Door Ford Murray Body in GREAT shape it even has the Murray Emblem on the bottom right side of the cawl.
Keep On Truckin'
Veger is offline   Reply With Quote
Old 07-25-2014, 11:02 AM   #27
Veger
Veger's Avatar
OK I might be close to my problems or should I say for my bothers coupe lol Anyways last month I ran 3 gallons of Vinegar through it for a few days and we got a nice bucket of dirty water. A few days back I did the same thing and drained it last night. This time we got a frothy foam, Dad said looks like stop leak. Now if I am getting this under control with the Temp LoL wonder where the leak was to start with? GoFigure
