Old 07-22-2014, 12:23 PM   #1
Veger
Veger's Avatar
Default Kerosene and Gas?
Good Day everybody!
Let me first start with my New Car Lol
NICE huh lol Anyways my question to yual is this. Somebody at a car show said IF your car is overheating that he would add a quart of Kerosene to his tank of gas to cool it down some. Doing so would do away with the need to using a lead additive also. Anybody out there have anything to this?
Thanks for the Help and Keep On Truckin'
Veger is offline   Reply With Quote
Old 07-22-2014, 12:27 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Kerosene and Gas?
I would not do this. I have never personally had a model A run hot. I have been around 3 model A's in my family and several more that friends own and they do not run hot. When properly tuned they run well and at normal operating temperature. I would do a check of your ignition system and your cooling system. Make sure you are properly tuned and the radiator and water pump are working properly as well.
You have a very nice looking 29 fordor. Get it running well and enjoy it.
Old 07-22-2014, 12:31 PM   #3
Veger
Veger's Avatar
Very cool thanks for the Info and the Fordor runs GREAT lol its my brothers coupe that has a little issue running to slow or to fast will cause it to over heat a bit. Has a new water pump in it and have run vinegar through it and doing so one more time. I might think it has something to do with the settings cause his spark advance runs best half way while the other three run Great all the way down. Go figure.
Keep On Truckin'
Old 07-22-2014, 02:32 PM   #4
Willie Krash
Willie Krash's Avatar
What does overheat a bit mean? My car runs 180° most of the time but on very hot days 10° more. Are you hitting a boil point?
Btw the degree symbol is obtained by alt 0176
Like this °
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 07-22-2014, 03:21 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Veger View Post
Good Day everybody!
NICE huh lol Anyways my question to yual is this. Somebody at a car show said IF your car is overheating that he would add a quart of Kerosene to his tank of gas to cool it down some. While adding kerosene may help with upper end lube much like adding MMO, I can't see how it would make a cars cooling system cool better. Doing so would do away with the need to using a lead additive also. A's don't need lead in the fuel. Anybody out there have anything to this?
Old 07-22-2014, 03:23 PM   #6
Bob/Kansas City
Bob/Kansas City's Avatar
Nice car LOL
Bob/Kansas City is offline   Reply With Quote
Old 07-22-2014, 04:00 PM   #7
Mike V. Florida
Sorry for being so rude and not mentioning that it is a fine looking car and I wish you many many happy drives.
Old 07-22-2014, 04:46 PM   #8
Veger
Veger's Avatar
Lol Mike your info was very helpful as always from this site Thanks and that Fordor is heading to The big show this weekend I'm sure it will be a Head turner.
The car is ither pushing the water out the overflow or boiling it out lol cause He will have to stop and add water to it once the motometer shows it so hot.
Keep on Truckin'
Old 07-22-2014, 04:52 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Like this °
OK, I have to try this...........190
Nope, it doesn't work for me.
Old 07-22-2014, 05:01 PM   #10
Old182
Old182's Avatar
Kerosine, or K1, is a middle distillate and has an end boiling point (~550*F) between gasoline (437*F) and diesel fuel (640*F). Essentially, kerosene is jet fuel (Jet A) and becasue it's nearly all straight-chain paraffin, it has no real octane number and will lower the octane rating of your fuel by roughly the volume amount you add to your tank. I've heard in the 1930s farmers would start their Model A trucks on gasoline and then fill them with kerosene to run the rest of the day (hauling vegetables and fruit from the Hudson Valley to New York City). But with an end point of ~550*F, it's doubtfull it will completely combust leading to oil dilution and washing of the cylinder walls and carbon buildup in the ring areas. Personally, I wouldn't put kerosene in my tank (but then, I don't use MMO either).
Old182 is offline   Reply With Quote
Old 07-22-2014, 05:05 PM   #11
mshmodela
mshmodela's Avatar
0 C = 212° F on a Macbook it's [shift]+[option]+8
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-22-2014, 05:06 PM   #12
Fordors
Willie omitted one small detail, you need to use the ALT key with the numeric keyboard. I tried it and it works; BTW, that was the first time I ever used the numeric k/b!
92° here this afternoon, chance of severe storms late evening.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 07-22-2014, 06:02 PM   #13
Great Lakes Greg
Great Lakes Greg's Avatar
It may be worth noting that some new water pumps call for the impeller to be ground a bit if they are moving too much water, not allowing it to cool enough before it cycles back into the engine.
Great Lakes Greg is offline   Reply With Quote
Old 07-22-2014, 06:12 PM   #14
Veger
Veger's Avatar
I have been out starting it up and run the vinegar through it more. The more I start it up and feel the spark advance the more I think that is very Wrong. It really does run GREAT with the spark advance all the way up. Once I start pulling it down as I would mine to drive the more rougher it runs. I really think its in his settings and might need to get the ole books out and figure this one out.
Smiles thanks everybody and Keep on Truckin'
Old 07-22-2014, 06:36 PM   #15
Tom Wesenberg
Thanks!
190° I finally got it.
I had to hit the numers lock key, then the number pad.
How in the world is a person supposed to know these odd things?
If a person knew the right keys to push, you might even get a pizza delivered.
Old 07-22-2014, 07:14 PM   #16
CarlG
CarlG's Avatar
• 0149
— 0151
☺ 1
♂ 11
♀ 12
½ 171
¼ 172
¾ 0190
€ 0128
© 0169
Ω 234
¿ 168
¢ 155
Just to name a few
All while holding the "ALT" key down, num lock on, using the numbers on the key pad
There's a chart: http://www.tedmontgomery.com/tutorial/altchrc.html
It's also way different on a Mac, I haven't figured that out yet.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-22-2014, 07:29 PM   #17
Synchro909
Synchro909's Avatar
Great lakes Greg, With respect, I've heard the theory about water circulating too fast to cool before but I'm very sceptical about it. I figure if the water is circulating that fast, it's not spending much time in the engine either to get hot. End result: no difference - fast or slow so long as it's not too extreme
Old 07-22-2014, 08:51 PM   #18
Tom Wesenberg
That's also how I see it.
Old 07-22-2014, 09:11 PM   #19
nickair
nickair's Avatar
Too fast of flow will erode portions of the water passage due to cavitation, which also causes temporary air in the system. Not good for cooling or the block/head.
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
Old 07-22-2014, 09:28 PM   #20
charles in east texas
charles in east texas's Avatar
I like your 29 Town Sedan. Is it a Briggs?
I have an unrestored Murray 29 Town Sedan.
Charles
charles in east texas is offline   Reply With Quote
