without a starting crank can an engine be gentily rotated by moving the fan belt??? Not started by just to see if the motor is not seized??
Not necessarily ALWAYS. I have been able to "rotate" SOME engines by the belt, while others would not rotate so easily, depending on how "un-stuck" the particular engine is, and on how tightly the belt grips the crank pulley. DD
A lot of this may depend on how worn your engine is.
New engines with new compression tend to be harder to turn and start with a crank. Older engines - like the original engine to my truck, could be turned with a crank held in two curled fingers (no thumb!) and would certainly start - but had no particular power and one of those "extended" crankcase breather thingies - and an accessory trail of blue vapor. Joe K
Shudda kept the horse. |
Pull the plugs and turn away.
it's all good
A number of the vendors offer a wrench that is like a socket ,to be used for this purpose.
It really is a special bolt, so why is it called a nut?
| Thread Tools | |
| Display Modes | |
