Old 06-03-2014, 11:25 PM   #1
Alley Kat
Default What flatheads will fit in a 1938 ford standard
Hey fellow builders I just started a 38 that has juice brakes and a 39 tranny but no motor. Will a 8 BA flathead fit or do I need to stay with an 59AB.
Alley Kat is offline   Reply With Quote
Old 06-04-2014, 05:00 AM   #2
Zeke...PA
Zeke...PA's Avatar
Default Re: What flatheads will fit in a 1938 ford standard
I have an 8BA in my 37 Tudor, fit is OK, I have an alternator with 13" fan attached, used a crab distributor . Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 06-04-2014, 03:35 PM   #3
tubman
tubman's Avatar
I think the only swap that wouldn't be easy is a V8-60 into a '51-'53 Fordomatic vehicle.
Old 06-05-2014, 11:55 AM   #4
blucar
blucar's Avatar
The only trick to putting an 8BA/8CM engine into an early Ford is the front motor mounts.. You'll need to use truck and/or '49-50 Merc water pumps with the '49-50 Merc motor mount spacers under the water pumps. The truck pumps will generally have wider belts than the car pumps.
You will also have to use a truck and/or Merc bell housing to adapt to your transmission..
If you use '37-39 style exhaust manifolds in lieu of late model, there will be more clearance over the steering gears..
The attached pix are of an 8BA engine in my friends '37 Ford pickup..
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 06-05-2014, 12:31 PM   #5
38 Hump
I have an 8BA in a '38 Standard Tudor. Truck water pumps/ motor mounts, stock exhaust manifolds (now Fenton headers), T-5 transmission, Walker radiator, electric fan and shroud. No problems what-so-ever.
38 Hump is offline   Reply With Quote
