Old 05-10-2014, 10:40 PM   #1
46WINE
Default Oil?
I understand that it is a good idea to use oil in the flathead that contains zinc. What kind or brand of oil do people recomend?
46WINE is offline   Reply With Quote
Old 05-10-2014, 11:04 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Oil?
Most oils used for diesel has zinc. Rotella t
Old 05-11-2014, 12:31 AM   #3
ford3
Default Re: Oil?
oils that have sj-sl or sm in the donut on the front of the container has all the zink you will need, any other letter combination is not recommended, do not use the oil that has the red circle on the container that says for gasoline engines, that is the new oil designed for modern engines with roller tappet cams, those engines do not need zink, don't use it in older engines
ford3 is offline   Reply With Quote
Old 05-11-2014, 01:06 AM   #4
mike42
mike42's Avatar
Default Re: Oil?
Valvoline VR1 20W-50
mike42 is offline   Reply With Quote
Old 05-11-2014, 12:37 PM   #5
Reisterstown Ray
Default Re: Oil?
I use Castrol 30W in my 37 Tudor, seems to work well. Ray
Reisterstown Ray is offline   Reply With Quote
Old 05-11-2014, 07:39 PM   #6
russcc
Default Re: Oil?
VR-1 is available at NAPA
Old 05-11-2014, 08:22 PM   #7
paul2748
paul2748's Avatar
Default Re: Oil?
Castrol 20-50, Rotella T 15-40
Old 05-11-2014, 09:03 PM   #8
elwood
elwood's Avatar
Default Re: Oil?
Castrol 20-50 + STP
elwood is offline   Reply With Quote
Old 05-11-2014, 09:13 PM   #9
aussiesteve
Default Re: Oil?
Thats what I use in my cars.
aussiesteve is offline   Reply With Quote
Old 05-11-2014, 10:22 PM   #10
B-O-B
B-O-B's Avatar
Default Re: Oil?
I just changed oil in the 34 roadster & used castrol 20/50 + a qt of MMO. I could not believe how much quieter the engine is. The was a bit of valve noise before now you can hardly hear them.
One of these years I need to get that *** paint off there. Blue ,green,black, red anything but orange. What do some folk use for common sense,maybe the guy was /is colorblind.
B-O-B is offline   Reply With Quote
Old 05-12-2014, 08:54 AM   #11
green50
green50's Avatar
Default Re: Oil?
Brad Penn 20w50.
Gene
green50 is offline   Reply With Quote
Old 05-12-2014, 11:06 AM   #12
46WINE
Default Re: Oil?
Thanks every one for your help and information. Now I can make sure the right oil is in my 46.
