Old 04-27-2014, 07:12 PM   #1
1952henry
1952henry's Avatar
Default Fog light innards
Can someone post a picture of the internal parts of Ford (Unity) foglights? Specifically the bulb retainer, if there are such pieces? Thanks in advance.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-27-2014, 07:52 PM   #2
40cpe
40cpe's Avatar
Default Re: Fog light innards
Are you referring to the bulb-and-socket type? If so, I don't have one near right now, but they took a bulb with a flange similar to the early headlights.
Old 04-27-2014, 08:34 PM   #3
1952henry
1952henry's Avatar
I believe so. Was there little spring clips to hold the bulbs? Have a picture of such lights as a reference.
http://www.bing.com/images/search?q=...lectedIndex=18
Old 04-27-2014, 09:57 PM   #4
keith oh
keith oh's Avatar
1952henry, Polosi better convince their EPA of that since they won't allow natural gas to be used to power natural gas pumps , must use electricity in new applications. No problem though, Obama just won't let the new transfer pipelines lines to be built.
keith oh is offline   Reply With Quote
Old 04-27-2014, 10:26 PM   #5
40cpe
40cpe's Avatar
Those look like sealed beam lights. Yes, there are spring clips to hold the bulb in the retainer ring. I think NAPA sells them. If I remember correctly, there are four clips per bulb.
Old 04-27-2014, 10:28 PM   #6
Don Rogers
Don Rogers's Avatar
Henry, With no year specified, I can only guess as to what you need. Here is an internal picture of a 1934-35-36 Unity sportlite
Don Rogers is offline   Reply With Quote
Old 04-27-2014, 10:38 PM   #7
40cpe
40cpe's Avatar
They are part number 6598 in the upper left of the attached
http://www.unityusa.com/assets/image...PartsSheet.pdf
Old 04-28-2014, 04:01 AM   #8
1952henry
1952henry's Avatar
Thanks all. So 'tis just the little spring clips that locate the bulb assembly. I really appreciate that.
Keith, maybe the pumps can be plugged into a "currant" bush.
