Old 04-01-2014, 03:55 PM   #1
hege101
Default A Model Shocks
Can anyone out there tell me how in the world you take a part a 1930 Model A ford shock. I drove the two pins out and took off the outer case a locking ring. Even took one to the machine shop and they could not get it apart. I'm sure it's something simple but we could not figure it out.
hege101 is offline   Reply With Quote
Old 04-01-2014, 04:22 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: A Model Shocks
A search will find a wealth of info on the old shock rebuilding.
Old 04-01-2014, 04:36 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
You need some heavy duty tools and heat.
I assume it's the inner nut that is stuck. The top tool is the one I made for that.
Old 04-01-2014, 06:01 PM   #4
Kevin in NJ
You need a 1 9/16 deep impact socket and a 3/4" air impact. Securely mount the shock and run it. On shocks that are not rusty the impact will get it apart. A few may need the outside heat cycled to about 300 degrees a couple of times. Then it hit it with the impact.
Kind of a real short answer. I need to do a better write up at some point. There are a lot of little details that get you a good finished shock.
Old 04-01-2014, 06:54 PM   #5
dave in australia
Unless some previous 'expert' rebuilder placed a few spots of weld on the inner cap to hold it in place. Had to use a dremel on them before using the sockets.
dave in australia is offline   Reply With Quote
