Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Re: 55 TBIRD Engine & Tranny...what do I have
The trans is not making the engine run at high RPM's the rear end is what determines that. you proably have a high ratio rear end.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Is the transmission a straight 3 speed or is it a 3 speed with overdrive? If it is an OD maybe it's not working (fuse, solinoid etc.).
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
There is a Y-Block web site online with pictures that may help you out.I forget the address but it should come up on a search.Try Google,its a good searh engine.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
If It is a Y-Block you can tell buy the valve covers.First do the covers have 2 nuts on top at each end, if so it's a Y block, also do they have a decal that say's Thunderbird in white letters, if so it is a Y block.
