I've got one of Brussegard's upper steering bushings that fits in the column tube, got many years ago. There are two small set screws at the top of the bushing that I can't get to; does anybody know how this works. Would imagine the set screws are suppose to lock on to the steering shaft but I don't see how to make that happen.
I just ground down the correct size allen wrench so that it fit in the tight space.
#4 | |
The Brusegard (sp?) upper steering column bearing is the Cadillac of these upper column bearings being offered, but for those not willing to spend that many $$'s there are other lower cost ball bearings that also work well. One is still offered by FoMoCo but I don't have that part number handy. The other option, that I am aware of, is a flanged ball bearing with the correct ID & OD. It is actually a wheelbarrow wheel bearing available at TSC for about $3.00 to $4.00. I will edit this post later with that part number.
These previous posts listed below have pictures and part numbers of these bearings. http://www.fordbarn.com/forum/showth...column+bearing http://www.fordbarn.com/forum/showthread.php?t=61577
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-18-2014 at 05:37 PM. |
#6 | |
thanks a bunch , It looks like I need a little practice on the search feature, I pulled up a few threads but none were the same as you all sent to me .
Thanks again! Fordestes, |
Remember, a wheelbarrow bearing carries a lot more load that an upper steering column bearing!! The original was a bushing, and the later ford bearings were nothing to right home about in the strength department. Even tilt Chevy column bearing wouldn't last two minutes in a wheelbarrow environment.
I use the rubber bush from macs and drop a modern bearing on top of it .
JM 35 Sedan has the answer. Use a "wheelbarrow" bearing and you will be plenty satisfied.
This is one place where we all seem to want to over-do a fix to a simple problem. If a $4 bearing will work, why use a $15 one? |
| Thread Tools | |
| Display Modes | |
