Guest
Posts: n/a
The trouble with fitting PS to a manual steer system is the gearing, the ideal ratio is 15-1 or less. You have 18-1. I think unless you can make some major pressure reduction adjustments, steering will always become uncomfortably lighter the faster you go. The info on pump adjustment is excellent & very interesting, I hope it works out! If not, try disconnecting it & put some decent pressure in your tyres. |
| Thread Tools | |
| Display Modes | |
