Go Back   The Ford Barn > The Archives > Early V8
Old 03-23-2005, 01:29 PM   #1
Guest
Posts: n/a
Default electric fuel pump
Who makes a good dependable elec fuel pump and regulator or what combination for flathead 2x2's or 3x2's 97 carbs. Thanks Richard
Old 03-23-2005, 02:11 PM   #2
Guest
Posts: n/a
Default Re: electric fuel pump
I used a pump from Sacramento Vintage Ford and a Holley pressure regulator that is set up as a fuel block for two carbs. Speedway and probably any speed shop sells 'em.
Old 03-23-2005, 03:31 PM   #3
Guest
Posts: n/a
holley "red" pump and low pressure regulator,got mine from summit
Old 03-23-2005, 05:39 PM   #4
Guest
Posts: n/a
i use an airtex #el8016 pump, available from most all the vendors here in vermont. puts out around 3 lbs. pressure. costs $37.00-$50.00 depending on where you shop !! it pays to look around. they have been very dependable, are small and easy to mount.
Old 03-24-2005, 12:21 AM   #5
Guest
Posts: n/a
Richard - Holley makes an excellent rotary pump and a good regulator. Both are available thru either Jegs or Summit. The problem is to find a fuel pressure meter that will read accurately in the 2-3lb area. Ken(SC)
Old 03-24-2005, 07:22 AM   #6
Guest
Posts: n/a
George, is that a 6V or a 12V?
Old 03-24-2005, 01:05 PM   #7
Guest
Posts: n/a
12 volt
Old 03-24-2005, 01:09 PM   #8
Guest
Posts: n/a
BRAIN FADE !! the correct number is e8016s, NOT el
Old 03-24-2005, 01:42 PM   #9
Guest
Posts: n/a
Thanks for all the info.Richard
