Old 12-20-2013, 01:54 PM   #1
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Whats happening here
Originally Posted by William Kelchner View Post
Ok here are photos of the cup --- One is definitely thicker than the other..
The parts pictured appear to be original style. Reusing the pictured parts and setting them up correctly will be the easy fix. I use the replacement style setup with the rubber ball and think it is a better idea because the original metal to metal setup tends to wear out and can contribute to front end shimmy. Being as most model A's aren't used for primary transportation,wear on the radius ball won't be as big of a problem. The replacement setup uses longer bolts to compensate for the extra thickness of the thicker cups. If you changed to the replacement setup, the two longer bolts in the bell housing would have to be replaced. I know that you've already had problems and replacing the longer bolts can be tricky. If the radius ball is in pretty good shape, the original setup will probably be your easiest bet. If it is too tight with the cupped washer, then don't use the washer.
Old 12-20-2013, 02:14 PM   #2
William Kelchner
William Kelchner's Avatar
Well true Purdy, car does not get many miles on it, I normally drive my 64 Impala convert, that way I know I'll make it home (not meant to be inflamatory), I like my 30, but the last 4 trips (under 10 miles) did not end well. 2 with total lack of power, one with total lack of power and fuel pouring out of my fairly new Zenith, and 1 trip on a roll back -- so I am suffering from a total lack of confidence. So new rebuilt dist with original setup, no overheating issues, timed to your specs, radius ball (to be completed tonight with the original stuff).
Looking at the radius ball cup the top piece really looks strange with that extended lip, but not having seen an original guess someone here would have mentioned it.
So, I'm going in, come what may. Supposed to be nice Sunday. I will take the car out for a ride but as always have one hand on the ejection seat lever. Thanks for the inputs. Have a great weekend.
William Kelchner is offline   Reply With Quote
Old 12-20-2013, 03:04 PM   #3
William Kelchner
Ok its back together - gotta run out and buy some cotter pins. I put the modified washer on top. Prior to starting all this I had considerable up and down movement at the joint - I have none now. Of course the thing was put together incorrectly by a previous owner.
Checked the radius ball and I've seen rounder concrete blocks...
I'll see if it drives any differently when I take it out Sat or Sunday. Thanks again.
Old 12-20-2013, 03:53 PM   #4
CarlG
CarlG's Avatar
...- gotta run out and buy some cotter pins...
http://www.fordbarn.com/forum/showth...6284&showall=1
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-20-2013, 05:40 PM   #5
William Kelchner
Well my radius ball cap assembly looks like everyone else's so I must be close.
Thought I would start it up and celebrate the event ---- refuses to start, even try to start despite voltage, gas. Closed the hood, said a prayer for the car and wished it well wherever its new home will be.....
It was an adventure.
Old 12-20-2013, 03:35 PM   #6
Timberbeast
Timberbeast's Avatar
Talking Re: Whats happening here
The Model A can be learning adventure. I've had my share over the years, I just take it in stride and never leave home with my AAA card.
Semper Fi
Jerry
Timberbeast is offline   Reply With Quote
