Old 10-29-2013, 11:26 AM   #21
KiWinUS
KiWinUS's Avatar
Default Re: Ethanol gas
I run Ethanol gas in my stock 36 for , drive her all over & never a problem ! Atleast not in the last 8 years .
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 10-29-2013, 12:15 PM   #22
Tim Ayers
You can also use a product called Star Tron by Star Brite. It is a enyzme that counteracts the effects that ethanol-based gas creates.
Way better than Sta-Bil. In fact, I've used it to restore stale gas. I was amazed how well it worked.
Here is the link to the company. I am in no way associated with them, just use the product and know a bunch of others who do as well.
http://mystarbrite.com/startron/
Old 10-29-2013, 12:47 PM   #23
1952henry
1952henry's Avatar
Originally Posted by dwkahler View Post
hi to all,my name is don.
i own a 1953 ford f 500 truck,with the flat head v8.
i recently changed the fuel pump,and replaced the fuel filter with
a filter that i got off the shelf. i changed the oil,after changeing the fuel pump,as this was recommended per fuel pump instructions.
i thought i made a good fix,however it began to run very ruff a short time later. it was my thinking that a good tune up,and new carb would fix this situation.i believe that gas is somehow leaking into the crank case,as i can smell it from the dip stick.what is causeing this? is it the off the shelf fuel filter? i am now wondering if this motor needs a compleate rebuild?
thankyou for any advise.
don
In addition to Daytona, Charlie NY on this site has quality parts.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 10-29-2013, 07:04 PM   #24
paul2748
paul2748's Avatar
We have had 10 % ethanol around here a long time. I have run one car on it ever since it came in (302 Ford). The other cars I have I also used it, including two trips from NJ to the West Coast in my stock 56 TBird and have never experienced any fuel component problems with it. Cars are used extensively.
I think a lot of people are making a mountain out of a molehill. Just change the parts that may have problems with ones that are ok for the ethanol. It's probably going to be a long time before the ethanol situation changes, if it ever does. We have to deal with it.
I thought the lead issue had died a long time ago. As long as you are not using the car extensively you don't need an additive and if you do, get hardened exhaust valve seats.
Old 10-29-2013, 08:07 PM   #25
barnfind
StaBil Blue Marine Grade seems to work pretty good for long term storage protection.
I spent over $2000 on new carbs, injectors, and fuel pumps in one year for multiple vehicles due to the eCRAP gas. Next door neighbor had the same experience at the same time with his fleet.
In a Red state, $2000 is considered a little bit more than molehill.
barnfind is offline   Reply With Quote
Old 10-29-2013, 10:28 PM   #26
46woodie
Your right, this site has so many drama queens it's just hysterical to read the threads. Been using E10 for 10-15 years in bikes, lawn mowers, new cars and the old cars with no problem. Hell, if it was that big of a problem there would be a towing company on every corner.
46woodie is offline   Reply With Quote
Old 10-29-2013, 11:14 PM   #27
Ross F-1
Ross F-1's Avatar
I'd be curious which "red state" you're in? I think based on what seem to be clusters of problems like yours, that local fuel distributors may be the cause of some problems. They may be adding more than the stated 10% ethanol, especially when gas prices go up. Or maybe their quality control sucks. There are 3 major refineries serving my area, and one has a history of contaminated fuel, the last one disabling almost a thousand cars in 3 days.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-30-2013, 06:34 AM   #28
Tim Ayers
It really is a problem if the gas sits. If it used up and is somewhat fresh, there shouldn't be too many issues.
For an old car, sitting in a tank for over 6 months or so it does start to create problems. This is fact and not drama.
Old 10-30-2013, 06:47 AM   #29
46woodie
Why would your car sit for 6 months? They're automobiles, meant to be driven unless you have a museum. ANY fuel will give you problems if it just sits in the system for 6 months. Gas it up, drive it and quit whining
Old 10-30-2013, 06:56 AM   #30
Todd'sflathead
Adding ethanol to gas is like watering down your beer when you buy a gallon of gas you want a gallon of gas.
Todd'sflathead is offline   Reply With Quote
Old 10-30-2013, 07:11 AM   #31
46woodie
Todd, it's obvious why they call you "flathead". You are not watering gasoline down by adding ethanol. Don't believe me, try putting a match to a glass of water. Now try this same thing to a glass of ethanol. Geeeeesh!
Old 10-30-2013, 07:34 AM   #32
46woodie
I hear ya! Been using E10 for years in mowers, snow blowers, old cars, new cars, motorcycles, never had fuel problems. These guys are confusing other problems with "alcohol gas" phobia.
Old 10-30-2013, 07:56 AM   #33
Tim Ayers
No one is whining. At least in NJ, I wouldn't take a restored car out in the winter since they salt roads so heavily.
Fellas, it seems like people's emotions are getting in the way of the facts in this thread.
To each his own I guess.
Old 10-30-2013, 08:02 AM   #34
GOSFAST
GOSFAST's Avatar
Here in N.Y. we have a 10% mix and have never had a single "fuel" issue with any builds we've done. The Flathead Merc in my signature has been running on it for a while now with no adverse effects, over 12,000 trouble-free miles on conventional pump-gas.
This also includes as well all the other mfr's we get to do. All the N.Y. "streeters" here run basically on the same fuel!
Seems the ethanol, corn-based fuel, doesn't react like methanol and other alcohol related fuels, with the rubber content.
Thanks, Gary in N.Y.
P.S. You can do a very simple test with any fuel by putting a short section of rubber hose in an inch of fuel in a metal coffee can and watch for a reaction. I have a conventional piece of rubber fuel line "soaking" in some straight E-85, this 85% ethanol, for a few weeks now with no change whatsoever.
GOSFAST is offline   Reply With Quote
Old 10-30-2013, 08:12 AM   #35
Mike51Merc
Mike51Merc's Avatar
Ethanol may not be the best thing for rubber parts, but it's not like they just invented it to mess up old cars.
I've been running E10 for years with no problems. I just make sure I stabilize it if the vehicle is going to sit for more than a month or so.
Mike51Merc is offline   Reply With Quote
Old 10-30-2013, 10:12 AM   #36
46woodie
Mike, love your 51!!
Old 10-30-2013, 12:36 PM   #37
FL&WVMIKE
FL&WVMIKE's Avatar
Ethonol IS "watering down" the gasoline. Alcohol does not have the energy stored, by volumn, as Gasoline. Ask any Chemistry student.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 10-30-2013, 01:26 PM   #38
Mike51Merc
Mike51Merc's Avatar
MIKE
This is true, plus alcohol soaks up water, making it even more watered-down.
Old 10-30-2013, 01:45 PM   #39
JeffB2
JeffB2's Avatar
Good news on the horizon but take the time to give this a read:http://www.fool.com/investing/genera...0000013&lidx=6 When I retired I invested some of my IRA in oil stocks in the Bakkan and also VLO and they are doing well also this company:http://www.fool.com/quote/nasdaq/linn-co-llc/lnco Compare the rate of dividend to what banks and CD's now pay and you can see it is a money maker.
JeffB2 is offline   Reply With Quote
Old 10-30-2013, 01:48 PM   #40
JeffB2
JeffB2's Avatar
Well,almost Halloween so here is something SCARY! https://www.google.com/search?q=etha...iw=994&bih=612
