Old 10-03-2013, 11:09 PM   #21
G.M.
Thumbs down Re: Ignition problem, could use some insight.
Originally Posted by Automotive Stud View Post
I thought the same, but I guess with only 11 volts it can still spin the 6v starter with no problem. Odd my volt gauge looked okay until it quit, though it clearly isn't charging at the moment. Hope to have it tested today. When I bought the powermaster in 2010 there was nothing but great reviews, now I'm seeing a lot of not so nice things about them.
Your resister may not be matched up perfectly for the coil. When the battery gets low it may spin the engine but the load on the battery from the starter
pulls the voltage to coil lower. Some times the engine will fire as soon as you let off the starter button. The engine is still cranking and the voltage to coil increases enough to fire the plugs. It will also kick start with a low battery.
G.M.
www.fordcollector.com
Old 10-14-2013, 08:18 AM   #22
Automotive Stud
Automotive Stud's Avatar
Default Re: Ignition problem, could use some insight.
G.M.
I think you may be on to something. I replaced both belts and got them good and tight, everything seemed fine again. I took a ride to Napa about 5 miles away to return the incorrect belt and had the battery tested there just to make sure it's good. It started fine and I went to my friend's house on my way home. When I went to leave there not even 10 minutes later I had no spark again. Same problem as before, nothing with a test light on the coil or new ballast resistor.
He gave me a ride back to my house where I got another coil. After that it started right up. Unfortunately, I left the coil wire hanging and the belt wore through it before I got the rest of the way home. After another ride back to my house for another wire, the car still wouldn't start. This time I bypassed the ballast resistor and it started right up. I'm thinking the new Mallory ballast wasn't really matched to the old yellow top '60's Ford coil I threw on there. I hope that's the case anyway.
Automotive Stud is offline   Reply With Quote
Old 10-29-2013, 12:36 PM   #23
Automotive Stud
NOS Mallory coil installed last night and the new ballast is still on there. Started right up but haven't had a chance to road test it yet.
