Old 09-12-2013, 04:24 PM   #1
Richardtx
Default overdrive kickdown switch install
What is the correct way to install the kickdown switch under the gas pedal? Does it just touch the pedal or do you leave a determined distance between pedal and switch? Thanks, Richard
Richardtx is offline   Reply With Quote
Old 09-12-2013, 04:29 PM   #2
40cpe
40cpe's Avatar
Default Re: overdrive kickdown switch install
I don't know the "official" answer, but it must be mounted high enough above the floorboard, matting, etc, for the accelerator to push the plunger down when the pedal is full depressed. On the other hand, I have pushed the bottom of the switch out because it was mounted too high, allowing the pin to depress too far.
It is a trial-and-error thing, I would want it to just barely activate with the accelerator on the floor.
Old 09-12-2013, 04:33 PM   #3
CarlG
CarlG's Avatar
On my 53 Merc I had a hundred years ago, I gave up on the floor switch and mounted a push button switch (kinda like the starter switch) under the dash.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-12-2013, 05:12 PM   #4
Big Red 51
Big Red 51's Avatar
Just switch the ignition off and on and it will do the same thing. Same idea as starter button.
Big Red 51 is offline   Reply With Quote
Old 09-12-2013, 06:19 PM   #5
trainguy
trainguy's Avatar
The switch should close just before the peddle bottoms out.If set up properly the trans come out of overdrive just like passing gear on a automatic trans.Be sure you hook the wire to the coil.It momentarily shorts out the coil to allow the O.D.to disengage.
trainguy is offline   Reply With Quote
Old 09-12-2013, 06:31 PM   #6
CarlG
CarlG's Avatar
I had forgotten that is what I use to do on my Dad's '56 Fairlane -- more often than using the kick-down switch.
Alaskan A's
