Old 08-29-2010, 05:04 AM   #1
verr1908
Question 1962 falcon
Hi could anybody help i live in england and have just purchased a 62 falcon wagon in the USA that has had a right hand front end collision and i am looking for body ,suspension & steering parts also looking for front end drawings of suspension & steering from a repair manual to help as i need to see what parts i need before the car comes home thanks mark
verr1908 is offline   Reply With Quote
Old 08-30-2010, 04:52 PM   #2
JeffB2
JeffB2's Avatar
Default Re: 1962 falcon
This will be the best money you can spend on your Falcon,click on www.ebay.com and put these two numbers in search: 160469110787 and 330366923047 You will find all the factory part numbers,exploded views of the cars entire construction.By entering the factory part numbers into Google search you should find many of the parts you need.
JeffB2 is offline   Reply With Quote
Old 08-31-2010, 12:48 PM   #3
2002p51
2002p51's Avatar
Join the "Falcon Registry" :
http://falconregistry.com/index.cfm
They have Ford shop manuals on-line.
Also check out "Auto Krafters" :
http://www.autokrafters.com/v4/go.gn...&product=45062
2002p51 is offline   Reply With Quote
Old 01-01-2011, 05:24 AM   #4
verr1908
Question Re: 1962 falcon
well the falcon has got to my workshop in england ,have all the suspention work carried out BUT the fender and hood i pickup on ebay and sent home with the car turned out to be 1962 hood and fender so i am stuck
.which way to go ?????.Do I look for another fender to match the 62 ,or look for the correct parts ie 1961 hood and fender and have them shipped to england
HELP !!!!!!!!!!!
Mark
Old 01-01-2011, 10:53 AM   #5
Dave72dt
If the body lines of the 62 and the 61 match up, it may be less expensive to find and ship a single fender than to find and ship another hood and fender. Can the 62 fender be used to repair the damaged 61?
Dave72dt is offline   Reply With Quote
Old 01-17-2011, 03:30 PM   #6
Blades
Blades's Avatar
I would try the following:
www.classicautoparts.com
www.dennis-carpenter.com
www.macsautoparts.com
My pal Garrett has a 62 Falcon and I have a 62 Fairlane. We get free catalogues from them. Also the stuff is pretty reasonably priced.
Good luck
_______________
Blades the barber
Blades is offline   Reply With Quote
