I have the luxury of painting a new garage/shop floor before I move all my collection of assorted rusty car parts, tools and paraphernalia into it. I'm looking for recommendations on what paint to use. Hopefully, something I can just roll on - I'm not really looking for a multi-stage process.
Thanks! Norm |
I haven't used it, but I've heard good things about the POR garage floor paint. I think that is a single stage process.
Red |
I have found the garage floor paint that uses xylene as a solvent to be excellent.
Available at Lowes for about $25 a gallon. 3 gal. did a 3 car garage. Easily applied with a paint roller and easy to touch up later if needed. Do not use water based products as they don't stick. |
When I built a new shop I researched all floor finishes. Epoxy, paints, tiles, etc.. All recommended application only on fully cured concrete, (months). So, I did nothing and moved in. No regrets. For oil and other spills I just spread some speedy dry and sweep up after a while. This reduces the stains and now it looks and smells like a real working garage. Some finishes can be slippery when wet.
So, check the labels for application to fresh concrete. JMO John |
#5 | |
Alan |
Bruce Works good Lasts long time |
A garage without a oil stained floor is not a garage !!
Like most people I researched the options. Finally ended up with a "HOT TIRE PROOF" 2 part floor paint from LOWES, VALSPAR brand. New house, etched the floor with muriatic acid (dangerous stuff!!!), let it sit a few weeks, and applied 2 coats. After the first coat pinhead size bubbles appeared. I was talking to the neighbor, house built same time, painted floor slightly after his, and he mentioned the same problem. Apparently still curing, moisture pushing thru paint. Sanded the floor, applied second coat and got rid of most of the pinhead size bubbles. Bottom line, if you drop, spill, etc anything on the floor, paper towels, 409,simple green, etc and it cleans as new.
Rolled it on and although 2 part a piece of cake! NO OTHER WAY TO GO!!! Last edited by Capn John; 08-03-2013 at 01:12 PM. |
I forgot to mention that this is a seasoned concrete floor - ten years old. By new, I meant clean and never painted. Perhaps "virgin" would have been a better term! It's only had clean cars stored in it, so now's the time. The Lowe's product sounds like the thing - I'll research it.
Thanks! Norm |
Take a look at this website http://www.legacyindustrial.net/cart/ and others to get some ideas for doing the job. Preparation of the floor is PARAMOUNT as it should be clean, dry and free of oil.
| Thread Tools | |
| Display Modes | |
