Old 07-09-2013, 06:20 PM   #1
oj
Default Buying a hub puller
I need a good hub puller and i do a lot of wide 5 stuff, i have heard the name winfield come up as being a good one.
What do you guys reccommend?
oj is offline   Reply With Quote
Old 07-09-2013, 06:32 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Buying a hub puller
Winfield Tool Works is a winner. That's what I bought. Well worth the $$. Click on photo to enlarge.
Old 07-09-2013, 07:05 PM   #3
oj
It looks to be well made, thanks for pic etc.
Old 07-09-2013, 07:14 PM   #4
Talkwrench
Talkwrench's Avatar
This couldn't have come at a better time as I need one too..
this style any good??
Old 07-09-2013, 07:16 PM   #5
flathead47
flathead47's Avatar
19Fordy , what is the maximum torque you apply when using this puller as I am having trouble getting my drum off with this setup ?
flathead47 is offline   Reply With Quote
Old 07-09-2013, 07:53 PM   #6
jim1920
jim1920's Avatar
Talkwrench...I have one of those pullers and it works great for me, but I think the hubs had been taken off before. It was just too easy.
jim1920 is offline   Reply With Quote
Old 07-09-2013, 08:09 PM   #7
bobH
Take a look at this before making a decision...
vintageprecision.com/products/hub_pullers
JMO
bobH is offline   Reply With Quote
Old 07-09-2013, 08:36 PM   #8
jrhaelig
jrhaelig's Avatar
x2 on the Vintage Precision. I like mine & it has gotten rave reviews from other guys as well.
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 07-09-2013, 08:50 PM   #9
Karl Wolf
Karl Wolf's Avatar
I bought the Winfield tool, but would go with the VP tool equally. I would recommend the high end pullers... The lesser priced tools will not pull a properly tightened hub from an axle, and axles are not cheap and were never easy to replace.
Karl
Karl Wolf is offline   Reply With Quote
Old 07-09-2013, 10:17 PM   #10
Talkwrench
Talkwrench's Avatar
Point taken.. Have contacted VP, see what happens..
Old 07-10-2013, 08:08 AM   #11
Fibber Mcgee
Fibber Mcgee's Avatar
I've got that one too. No problems yet as long as you tighten both sides equally.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 07-10-2013, 08:12 AM   #12
dwick01
dwick01's Avatar
Fibber or Talkwrench, where do you get these pullers?
dwick01 is offline   Reply With Quote
Old 07-10-2013, 08:18 AM   #13
Kube
Super Moderator
Kube's Avatar
I'd go with the KRW tool hands down.
Even pull, stronger than any other...well worth the cost.
There's one on ebay right now at $86, new in the box.
Old 07-10-2013, 03:24 PM   #14
Fibber Mcgee
I got mine from Macs a while back.
Old 07-10-2013, 03:34 PM   #15
done4
done4's Avatar
Send a message via Yahoo to done4
This is so timely as I have had the same dilemma. Thanks for asking!
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 07-10-2013, 06:39 PM   #16
19Fordy
19Fordy's Avatar
Not trying to be a "smarty pants" but it all depends on how much torqus was used to previously tighten the axle nut. Literature says it can be as much as 200 + pounds. With this type of puller you can apply as much torque as needed without damaging the axle, the nut, the studs or the puller.
Old 07-10-2013, 07:28 PM   #17
Talkwrench
Talkwrench's Avatar
I will not be looking forward to the removale when the time comes.. and more-so doing up a hub nut that size to 200 lbs.. Im sure I read 220 somewhere ..Gueezzzuuss! My torque wrench only goes to 150..
Old 07-10-2013, 07:51 PM   #18
Pete
If you put a big strain on the puller, say 75 to 100 ft lb and then apply heat to the hub area, it will almost always pop off with no further abuse to the parts.
I leave the nut screwed on flush when pulling so the whole assembly doesn't go flying across the shop. (saw that happen and can be dangerous)
If you lap the hub to the axle when assembling, you greatly lessen the chance of key way problems.
What does this have to do with the first question? Nothing.
Any of the above named "clamshell" type pullers will do a good job.
Old 07-10-2013, 08:02 PM   #19
Rich Overton
Before buying one you could consider renting one from VanPelt Sales. I did and a good local garage did the job for me. I can no longer do these types of jobs due to wrist problems. The guys at the garage could not praise the tool enough.
Rich O.
Rich Overton is offline   Reply With Quote
Old 07-10-2013, 08:34 PM   #20
ccnelson
I bought the Winfield tool and it work great for me.
ccnelson is offline   Reply With Quote
