Old 06-30-2013, 09:30 PM   #1
Nlbloch
Default Re: Help needed
removing the plugs does allow the crank to start more easily. But then when I put the plugs back in, hard to crank.
How would one address the hydra lock problem? If opening the plugs releases the pressure does that still sound like water on the cylinder?
Nlbloch is offline   Reply With Quote
Old 06-30-2013, 10:07 PM   #2
Russ/40
Russ/40's Avatar
If there was a hydra lock issue from a leaking gasket into the cylinder, removing the plugs and cranking it would expel it out the plug hole with force. Its not likely the problem, but that would cause the problem you describe.
