Old 06-19-2013, 08:01 PM   #1
Tikker
Tikker's Avatar
Default Loud Whistle From 94 Carburetor
I've got a nice rebuilt 94 carb on my '52 Customline, borrowed from my brother till I rebuild mine.
Had it on before and it worked great, gave it back to him to try and determine some problems he was having on his '41 PU.
Now I've got it back and it has the loudest whistle you can imagine.
I'm sure it's a vacuum issue, it's not the line to the wiper motor, all bolts and screws are tight. I've actually had it stop whistling at initial start-up, but it quickly goes into whistle mode.
My brother mentioned the possibility of the power valve.
I can't leave it like it is, any suggestions for a solution?
Tikker is offline   Reply With Quote
Old 06-19-2013, 08:15 PM   #2
ken ct
Default Re: Loud Whistle From 94 Carburetor
It could be the spring loaded little disc on the choke flapper is not opening when choked fully to let in some air??? ken ct. PV will not make any noise that i know of even if bad. Does it whistle when the choke plate is full open ??
ken ct is offline   Reply With Quote
Old 06-19-2013, 08:24 PM   #3
Gary in La.
Gary in La.'s Avatar
Could possibly be warped base of body where it mates to the carb base. I've had vacuum leaks there before on a 94 model 59 carb. Creates a very loud whistle.
Gary in La. is offline   Reply With Quote
Old 06-19-2013, 08:34 PM   #4
OhioRick
OhioRick's Avatar
Had this just this year and
I Traced it with a stethoscope to a hole in my cast base.
OhioRick is offline   Reply With Quote
Old 06-19-2013, 08:37 PM   #5
41ford1
41ford1's Avatar
Bingo!!
Both the bottom of the bowl body and the mating surface of the throttle body must be flat. File or machine as required. Thicker gaskets there sometimes cure the whistle.
41ford1 is offline   Reply With Quote
Old 06-19-2013, 08:47 PM   #6
Tikker
Tikker's Avatar
Choke full open.....
Old 06-19-2013, 08:51 PM   #7
Tikker
Tikker's Avatar
Great information, suspect base gasket as it's not in pristine condition,
That's an easy solution to try initially.
I'll update.
Old 06-20-2013, 10:01 AM   #8
Gary in La.
Suggest while you have it apart to take a piece of glass and tape a sandpaper sheet to it. Slide the 2 mating surfaces over it until have a uniform sealing surface. Sometimes using just a new gasket will still not seal good enough.
Old 06-20-2013, 11:23 AM   #9
Ralph Moore
Ralph Moore's Avatar
I would go with base gasket as well, a buddy's rpu was making the same noise with strombergs. We traced it to the carb base by pulling the windshield and I climbed over the engine while he drove, the sound was loudest going down the road about 35 mph.
Ralph Moore is offline   Reply With Quote
Old 06-20-2013, 12:50 PM   #10
ford38v8
ford38v8's Avatar
Ralph, I guess no speed bumps in Alaska, or your buddy would have heard some pretty substantial thumps and bumps!
Alan
Old 06-20-2013, 01:33 PM   #11
Lawson Cox
Lawson Cox's Avatar
Originally Posted by ralph moore View Post
i would go with base gasket as well, a buddy's rpu was making the same noise with strombergs. We traced it to the carb base by pulling the windshield and i climbed over the engine while he drove, the sound was loudest going down the road about 35 mph.
omg
Old 06-20-2013, 05:04 PM   #12
Mike in AZ
Mike in AZ's Avatar
lucky no moosie stepped out on road....yikes....the things we do, eh??....done the old ride-the-fender-and-dribble-gas-down-the-carb-while-moving thing back when....and still alive to tell about it...lol....Mike
Mike in AZ is offline   Reply With Quote
Old 06-20-2013, 09:27 PM   #13
Bluebell
Ralph, I'd have thought that whistle would have frozen solid, before it got out, at the Pole.
Bluebell is offline   Reply With Quote
Old 06-21-2013, 08:30 AM   #14
Ralph Moore
It was definitely not the proper way to do it. Don't try this at home kids. But our roads are not that crowded and it worked!
Old 06-21-2013, 09:13 AM   #15
32phil
Had the same problem years ago. it was the hidden screw that faces up when the carb is in place. I found it by rocking the top of the carb while the engine was running. Tightened the screw and the whistle stopped.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 06-21-2013, 09:44 AM   #16
ken ct
That screw up from the bottom is really not long enough,use a longer one cut down to just short of the bottom of the hole.Works just fine. ken ct.
Old 06-21-2013, 03:22 PM   #17
Tikker
Tikker's Avatar
Problem solved.
Removed the carb and didn't realize there were remnants of an old gasket on the manifold. Wire brushed that with a small wire wheel in my drill motor till clean (was surprised to discover the manifold mating surface was textured like a cheese grader). Installed a new base gasket.........no more whistle.
And nobody needed to ride under the hood.
Thanks for all the input.
Old 06-21-2013, 03:27 PM   #18
Ralph Moore
Well that's no fun
Old 06-21-2013, 03:47 PM   #19
TStiles
Darn. I'm west of you over on the peninsula and was hoping to run over for that thrill ride...
TStiles is offline   Reply With Quote
Old 06-22-2013, 07:17 AM   #20
dwick01
dwick01's Avatar
Some people pay good money to hear a whistle.........
dwick01 is offline   Reply With Quote
