Old 06-19-2013, 03:05 PM   #1
buddyholley19
Default Carb dripping gas onto floor
Will the carb leak fuel if the gav is not set correctly?
or is it a float issue.fuel leaked out onto the gound just before start up.thanks in advance .
buddyholley19 is offline   Reply With Quote
Old 06-19-2013, 03:09 PM   #2
Will N
Will N's Avatar
Default Re: Carb dripping gas onto floor
The GAV adjustment will not cause a leak. Either you're float level is set too high, or the needle valve is leaking, or the drain plug at the bottom of the lower body is leaking or you have a crack in the casting somewhere.
Will N is offline   Reply With Quote
Old 06-19-2013, 03:16 PM   #3
Russell in Tulsa
Or you are over chocking at start up. Release the choke after one revolution or don't use the choke to start and see if the dripping has disappeared.
Russell in Tulsa is offline   Reply With Quote
Old 06-19-2013, 03:28 PM   #4
Louis
Adjusting the gav. will not help, I close the shut off valve and run the carb. dry if I'm going to be setting for more then 20-30 min's, and esp. over night in the garage, to many reasons not to. these are 80-83 year old cars, I don't expect any recalls from ford any time soon .
I've suffered a great many Catastrophe's in my life.....most of them never Happened.
Louis is offline   Reply With Quote
Old 06-19-2013, 03:32 PM   #5
Patrick L.
Patrick L.'s Avatar
These things can leak just the fellas mentioned. Trying to stop some of these critters from leaking can make you pull your hair out. Apparently from looking in the mirror, I've had a lot of these leak over the years !
Old 06-19-2013, 04:15 PM   #6
Doot
Doot's Avatar
Is it an original carb or a Tillotson? If it's a Tillotson, Sometimes the carb body itself can warp over time because of the aluminum casting and cause it to leak through the gasket.
I agree with the guy above who said it's probably the float adjustment and/or bad needle valve.
I just had to do the same thing to mine!!!!
Good luck!
Doot is offline   Reply With Quote
Old 06-19-2013, 07:59 PM   #7
glenn in camino
glenn in camino's Avatar
I've tried everything but my carbs still drip a few drops in a day or so. My solution is a plastic paint bucket hung beneath the carb with a wire or zip tie
Old 06-19-2013, 08:17 PM   #8
SeaSlugs
SeaSlugs's Avatar
just make sure the plastic bucket wont get eaten by gas... had that goopy mess on the garage floor before...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-19-2013, 08:27 PM   #9
Tom Endy
Tom Endy's Avatar
Glenn:
Order a modern (Viton tip) float valve from Bratton's. Take it apart before you install it and clean out any brass machine particles residing inside. The valves work very good, but Bratton's is at the mercy of his supplier and they sometimes leave brass particles inside from the machining process. You may also want to replace the tank valve as well as it apparently is not shutting off 100%.
Tom Endy
Old 06-21-2013, 09:04 PM   #10
KGBnut
KGBnut's Avatar
I agree with Timothy Kelly, check the gaskets under the jets. Not only do those gaskets get old, but they are tough to get properly tightened without the proper tool.
http://www.brattons.com/product.asp?...Keywords=14080
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 06-22-2013, 03:53 AM   #11
johnbuckley
johnbuckley's Avatar
Possible causes of carb leaking: some of which have been already stated ..
1) float set level too high
2) needle valve leaking or its gasket leaking
3) leaking drain plug/gasket
4) cracked casting
5) leaking gasket at main jet or cap jet
6) hole in float
(7 also sometimes a leak at the inlet union is mistaken for a genuine leak elsewhere)
Old 06-22-2013, 03:57 AM   #12
johnbuckley
I..... solution is a plastic paint bucket hung beneath the carb with a wire or zip tie....
Doesn't this create a dangerous fire risk?
Old 06-22-2013, 07:21 AM   #13
Barry B./ Ma.
Barry B./ Ma.'s Avatar
A new tank shutoff valve with a stand up filter should solve the problem. The new valves are ball type and they never leaked for me.
Barry B./ Ma. is offline   Reply With Quote
Old 06-22-2013, 07:29 AM   #14
ora masters
hey BARRY where do you get the ball type shut off thanks ORA
ora masters is offline   Reply With Quote
Old 06-22-2013, 02:40 PM   #15
Barry B./ Ma.
I think mine came from Snyders but that was 8 or 10 yers ago. I believe all the suppliers (Macs, Snyders, Tams and Brattons) all carry the new style.
Old 06-22-2013, 04:33 PM   #16
Purdy Swoft
Purdy Swoft's Avatar
If you are running a Zenith carb and the float is set too high, it will stall when you put on the brakes. A couple of things that hasn't been mentioned as a possible cause is main and cap jets that are too short. I always try to use old original numberd jets because some repro jets are way off, especially old repro jets. If there happens to be too many gaskets under the main jet or stuck up in the lower housing, this will lower the main jet below the level of the fuel in the float chamber and cause a drip. I have found that the original type needle valves can work good. I give the needle a tap with a small hammer before installing the float, this seats the needle . I then blow air through the fuel inlet and check that the needle functions properly.
Old 06-23-2013, 04:39 AM   #17
johnbuckley
Dang me, well remembered Purdy! I always measure the jets for length- (not yet come across a short one, though plenty of time yet )
Old 06-23-2013, 05:57 AM   #18
ba49
I put a small shutoff valve right near the carb and I shut it off and let it run out of gas when I'm parking it for a while or putting it in my attached garage. Works good for me. I don't use the one inside the car.
ba49 is offline   Reply With Quote
Old 06-23-2013, 08:43 AM   #19
1931 flamingo
1931 flamingo's Avatar
Fix the carb, it should NOT be leaking. Get an electric fuel shut off switch, so much easier than the original.
Paul in CT
Old 06-24-2013, 05:23 AM   #20
Loyd Nix
After many attempts with various solutions I finally fixed the leak with an electric shut off as mentioned above.
Loyd Nix is offline   Reply With Quote
