#21 |
Heads off...freeze plug bulges confirmed...'39-40 221
#22 |
Distributor, water pumps, oil pan removed, yuk!!!! what a mess in side the block...sludge city!!! LOL!!! So far I can't see any cracks.
101_0892.jpg 101_0893.jpg |
#23 |
Took the head gaskets off yet?
Mart. |
#24 |
Mart,
I left the head gaskets on for now, to protect the mating surface from being damaged while taking the motor apart. 2012-12-29_12-03-35_363.jpg 2012-12-04_21-07-31_436.jpg |
#25 |
I think this motor has had work done to it in the past, found one of the tappets to be slotted, the rest are the non slotted type..
2012-12-29_12-07-26_346.jpg |
#26 |
2012-12-29_12-47-06_519.jpg 2012-12-31_12-16-41_201.jpg 2013-01-02_17-20-53_82.jpg 2012-12-29_12-04-22_471.jpg 2013-01-07_11-08-34_428.jpg |
#27 |
And more, Almost ready to bring the block to the machine shop for claeaning and a mag test for cracks. If all OK then a pressure test...I desided that I will bring the block to Eastwoods Auto Machine...
~0513779.jpg 2013-01-07_11-08-24_432.jpg |
#28 |
The last "Flathead" I tore down and got to this point, pulling the pan was painfull. It had the dreaded pan rail cracks on both side
#29 |
Hey Phil, up here in Me. the salt water is alot cooler than it is in Florida. the clams have to bury in the mud the keep warm. LOL Walt
#30 |
I don't see any sign of the steel sleeves in the bottom end pic. If it's still 3-1/16 I'd call it a 39 engine. Walt
#31 |
Walt, there isn't any sleeves, I will call it a 39..No cracks in the block that I can see...
#32 |
The block does not have any cracks in it and it passed the pressure test. More pics...
2013-03-01_12-17-56_600.jpg 2013-03-01_12-18-55_453.jpg 2013-03-01_12-19-13_951.jpg 2013-03-01_12-19-36_811.jpg |
#33 |
Looks very nice. Congrats on the crack free status. What process did they use to clean it up?
Mart. |
#34 |
It was dipped in a hot tank about 3 times, 2 days per dip. Mark at Eastwoods auto said it was a dirty block. After the hot dip Mark pressure washed it. He then rough bored the cylinders .030 over.
#35 |
Update, the motor is home from the machine shop, Eastwoods Auto Machine in Somersville CT. Took the advise of quickchange34 and mart and made a bracket to hold the motor from the exhaust ports...see pics...Thanks
~3338253.jpg 2013-05-28_14-48-12_885.jpg |
#36 |
I keep looking at the intake manifold surface on the block, Of all the pic I still cain't tell if it's a raised intake surface, in some of the pic it looks like it does. But, the engines with a raised surface were late 41-42 and had sleeves, so with no sleeves I'd call it a 39. Walt
#37 |
Walt, Yes it's a 39. Went to VanPelt sales webpage and I was able to figure it out by there section on how to ID a flathead motor....
#38 |
I see the head studs have been removed. Did this present any problems? It seems like the hardest problem with the crusty blocks I have worked on.
#39 |
I did try and remove the head studs myself, but they wouldn't budge. When the block was dipped into the cleaning tank the studs then were able to be removed. I had the machine shop remove them and two of them had to be drilled out.
#40 |
Just a little warning - don't run a tap down the head stud holes - they are a tight thread and a tap will open them out. Use a thread restorer or an old stud or bolt with a slot cut in it.
If you already knew this I apologise, but it isn't obvious to a novice. Mart. |
| Thread Tools | |
| Display Modes | |
