Old 05-16-2013, 12:52 PM   #3
Old Henry
Old Henry's Avatar
Default Re: Cooling system cleaning
Originally Posted by 36tbird View Post
Is there any worth to removing the thermostats while doing the vinegar cleaning? I also remember someone posting a tip to put some nylon hosiery over the lower outlets to keep the crud out of the radiator. Thoughts?
Trying the cleaning with the thermostats in will inhibit the flow of the vinegar through the engine and radiator. Best to remove the thermostats.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
