Old 04-12-2013, 12:50 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default 1940 Steering lock Disassembly
I have seen some previous post about how to get the steering wheel locking mechanism apart. I took one apart the other day and took photos so I thought I would share them here. Im assuming that the column is out of the car and on the workbench.
1. Remove the two screws that hold the switch to the housing.
2. I then used a staple puller,looks like a screwdriver with a forked blade, and worked it under the switch lever to pry it off. Its on a splined shaft.
3. I didnt do it on mine but go ahead now and remove the two drive rivets and remove the ON/OFF switch plate, It will make things a litte easier later.
4. Drill a hole in the bolt that clamps it to the column and back the bolt out with an easy out.
5. If you have the key ,turn it to unlock position and slide the lock assembly off the column tube. If you dont have a key and I didnt, I drilled a hole in the locking pin for the cylinder and tapped a 10/32 hole then pulled it out with my dent puller. Then the cylinder can be slid out and the unit unlocked using a screwdriver.
6. Once the unit is off the tube remove the detent ball and spring,its uner the large screwhead below the on/off lever.Reach inside the column hole and push the locking bolt all way over to the unlock position it should go far enough to get a couple of screwdrivers and fulcrum the cap off the end of the bolt. Them push the bolt back to the inside and it will come out.
Im sure there are other methods but this worked for me.
Old 05-12-2013, 10:28 PM   #2
Fred A
Fred A's Avatar
Default Re: 1940 Steering lock Disassembly
It has been a month but no flood of mindless comments agreeing that steering locks are cool and the mob is subscribed in no way mean that active builders won't need your pictures to solve the mystery of those Ford column drops. I sure saved it. Printed it out to insure that it will not be lost. nearly all my pre-'48 cars needed lock work that would have been easier this help. Thanks: Fred A
Fred A is offline   Reply With Quote
Old 05-13-2013, 07:28 AM   #3
Kube
Super Moderator
Kube's Avatar
Hi Ken, Wise folks will copy your photos and instructions for possible future use.
As you are now well aware, these locks come apart fairly easy ONCE the "tricks" are learned. I just did another last week. To this day, after countless assemblies, i still have to scratch my head in an attempt to jog the old memory bank.
Thanks for posting!
Old 05-13-2013, 08:16 AM   #4
Enbloc
Enbloc's Avatar
Great tech.
Enbloc is offline   Reply With Quote
Old 05-13-2013, 08:22 AM   #5
Fred A
Fred A's Avatar
I would love to see the breakdown for the really early drops. Thanks Again: Fred A
Old 05-13-2013, 10:18 AM   #6
19Fordy
19Fordy's Avatar
Wow, Those steering locks are an engineering marvel. Thanks for taking the time to take photos and posting the info. Just imagine how many of those locks have been "butchered"
by not knowing the little secrets.
Old 05-13-2013, 10:28 AM   #7
OLDTGUY
Thanks for the post.
JJ
OLDTGUY is offline   Reply With Quote
Old 02-03-2014, 04:52 PM   #8
rlittleco
Under the switch lever there is supposed to be a poppet ball and spring. can any one tell me where to get such an item?
Robt
rlittleco is offline   Reply With Quote
Old 06-12-2014, 05:57 PM   #9
moefuzz
moefuzz's Avatar
Ken,
Thanks for the great tech article.
I have 2 cars coming thru the system right now and both of them need keys/ignition so this article is a God send.
Thanks again,
moe
moefuzz is offline   Reply With Quote
Old 06-12-2014, 08:20 PM   #10
FlatHeadCoupe
FlatHeadCoupe's Avatar
Roy Nacewicz Enterprises
po box 544
Carleton, Michigan 48117
He has the column drop parts that you have asked about.
FlatHeadCoupe
FlatHeadCoupe is offline   Reply With Quote
Old 08-04-2014, 10:48 PM   #11
malpais
malpais's Avatar
Really helpful post! I'm trying to get a very rusty drop apart. I've done it before, but in this case the key cylinder (with key in it) wont budge. Got pin out clean, but no way to pull on or push on cylinder. Soaked the whole thing in Evaporust, as it's not supposed to act on anything but rust. Took some of the rust out.
Any ideas besides drilling out the whole cylinder assy?
The column lock is really stuck too, but key cylinder is first problem.....
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 07-27-2023, 04:52 PM   #12
danm
Great instructions - thanks.
danm is offline   Reply With Quote
Old 10-28-2024, 09:58 PM   #13
Ckrivin
Ckrivin's Avatar
Super helpful!! Thank you so much for the detailed response
Craig
89, 69, 53, and 40 Mercs
Ckrivin is offline   Reply With Quote
Old 10-30-2024, 09:41 AM   #14
Planojc
Planojc's Avatar
Just did my 35 steering lock and wish I had these instructions before. Thanks for the info.
Planojc is offline   Reply With Quote
