Old 05-04-2013, 03:04 PM   #1
Gary
Gary's Avatar
Location: Emeryville, near Oakland and the Sf Bay Bridge
Default Wood graining kits
Anyone know of wood graining kits or a patch kit, I really don not want to remove the dash from my 34.
Anyone had success with a patch kit ?
Thanks for taking the time to read the post.
Gary is offline   Reply With Quote
Old 05-04-2013, 06:27 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Wood graining kits
I have patched dashes ,specially were the hinges mark it ,post a photo .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-04-2013, 08:30 PM   #3
G.M.
There is a new method of wood graining. It consists of a tank of water and some sort of decal that floats on the water. I saw a Packard dash that was done the other day and it was the best dash I have seen. It don't look like a decal, it looks better than any wood graining job I have ever seen. $250.00 for the dash, glove box door, windshield and doors. I think it's called hydrograin?? G.M.
www.fordcollector.com
Old 05-04-2013, 08:30 PM   #4
Gary
Gary's Avatar
Thanks Ted, I will get a picture, I had masking tape all along the top and when I pulled the tape several big areas pulled off the metal. Pretty ugly.
What did you use ? Home Depot has a wood graining kit.
Gary
Old 05-04-2013, 08:32 PM   #5
Gary
Gary's Avatar
Thanks, I did see that stuff, I hope to patch it with out removing it.
Old 05-04-2013, 09:07 PM   #6
itsa52
itsa52's Avatar
There is also the vinyl film system they use for all the modern signage.. If there are not a lot of curves it could be applied in the car, but you would want to do the whole dash, not patch
itsa52 is offline   Reply With Quote
Old 05-04-2013, 09:14 PM   #7
itsa52
itsa52's Avatar
I just grabbed this http://www.rvinyl.com/Dash-Kits.html off of a Google search but there are plenty of others.
Old 05-04-2013, 09:51 PM   #8
Gary
Gary's Avatar
Thanks to all , itsa52 looks like that may be a winner
Thanks Barners one and all
Old 05-05-2013, 11:15 AM   #9
Digger
Digger's Avatar
I checked out that transfer system of woodgraining: go to cobraimaging.com, and you can see samples of the process done on utube. As an traditional woodgrainer, I am definitely going to try this alternate method next time... Pretty cool.
Digger is offline   Reply With Quote
Old 05-05-2013, 03:43 PM   #10
FlatheadTed
If you just pulled of the top layer (clear coat )then you may be able to re coat it with clear then rub back between each 4 coats ..If it worse than that then a full job is required ,The small part that I did I took some color lacquer to the job then eye matched some to the base of the back ground color ,then I used some timber wipe on stain (the paste type ) or you can use printers ink and something with a texture in it like Burlap or a bit of foam rubber to grain it ,then clear coat it . The sytiom that GM talks about is a membrane thats floats on water they spray a activator on it ,then they dip the object in it .it .I have seen a steering wheel done and it does a outstanding job Ted
Gary
Old 05-05-2013, 03:45 PM   #11
swoopNZ
MEMBER EMERITUS
I have had my '39 std and deluxe dashboards done by the water transfer method.
The grain is not 100% authentic but the finish is immaculate.
swoopNZ is offline   Reply With Quote
Old 05-05-2013, 04:22 PM   #12
Bruce in southern OH
Bruce in southern OH's Avatar
What did you use swoopNZ, information appreciated, Bruce
Bruce in southern OH is offline   Reply With Quote
Old 05-05-2013, 04:24 PM   #13
FlatheadTed
Hi Swoop Yes its real nice .We use the Grain it technology for a full dash ,My son just did a brook ville 3 window ,Collin W ,and a 39 mercury Conv bob ferbine ,Its comes out just about as good .
Old 05-05-2013, 04:33 PM   #14
FlatheadTed
The dip method is expensive ,Heres some shots of what we do
Old 05-05-2013, 08:44 PM   #15
swoopNZ
MEMBER EMERITUS
Ted,
Have you got an example of what you would use on a '39 deluxe ( medium tan base - straight grain )
Thanks,
Chris.
Old 05-05-2013, 09:28 PM   #16
FlatheadTed
Swoop ,I do have the straight grain Engraved plate ,thats does Model A, maybe 30, and later v8 ,I haven used it yet, This would likly be what you want , Ted
Old 05-07-2013, 12:28 AM   #17
swoopNZ
MEMBER EMERITUS
Ted,
I have that plate from Grain-It but not the rollers etc.
I might get you to do my next one.
Got a ballpark figure for a '39 dash ?
Thanks,
Chris.
Old 05-07-2013, 02:15 AM   #18
FlatheadTed
PM sent .Ted
Old 05-07-2013, 03:22 AM   #19
dumb person
dumb person's Avatar
Tried that. Worked ok in the winter but on a hot summers day it tends lift at corners and the wind catches it & it goes out the window.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-07-2013, 06:39 AM   #20
FlatheadTed
A coil, this one went out the window .
