Old 05-05-2013, 03:43 PM   #6
FlatheadTed
FlatheadTed's Avatar
Default Re: Wood graining kits
If you just pulled of the top layer (clear coat )then you may be able to re coat it with clear then rub back between each 4 coats ..If it worse than that then a full job is required ,The small part that I did I took some color lacquer to the job then eye matched some to the base of the back ground color ,then I used some timber wipe on stain (the paste type ) or you can use printers ink and something with a texture in it like Burlap or a bit of foam rubber to grain it ,then clear coat it . The sytiom that GM talks about is a membrane thats floats on water they spray a activator on it ,then they dip the object in it .it .I have seen a steering wheel done and it does a outstanding job Ted
Originally Posted by Gary View Post
Thanks Ted, I will get a picture, I had masking tape all along the top and when I pulled the tape several big areas pulled off the metal. Pretty ugly.
What did you use ? Home Depot has a wood graining kit.
Gary
http://www.flatheadted.com
Flathead Ted brake Floaters ,
