Old 01-25-2013, 09:43 AM   #1
purehotrods
Default Banjo Shock Mounts
City: Aledo
State: Ill
Price: 119.00
Pure Hot Rods answer to Henry's fluid shocks. We manufacture these MADE IN THE USA tube shock mounts that are an upgrade from the 48 Ford mounts. They are two inches longer and equal length with removable studs for custom applications. This allows for lowered cars to use an adequate shock length as well as being a great answer to a stock restoration. Hot Rodders and Restores alike have depleted the supply of original stock units, so here are bolt on, brand new mounts ready for your ride. We also offer the same mount that welds on any housing for that old school feel on your ground up build that is using a late model rear end, check our other listings. For $22 a pair, we offer stock type top shock studs. We are a full service Hot Rod shop specializing in Postwar Traditional Hot Rods. Any questions call Brian or Jake @ Pure Hot Rods (309) 582-3547
purehotrods is offline   Reply With Quote
Old 03-23-2013, 07:32 AM   #2
slug
slug's Avatar
Default Re: Banjo Shock Mounts
Do you have any pics showing an installed set up on a 32..shocks etc installed using your top and bottom mounts? Thanks, John
slug is offline   Reply With Quote
Old 03-28-2013, 06:34 PM   #3
Steve/IL
Steve/IL's Avatar
Same request as Slug! My thought is that there is not enough room on a 32-34 for your lower shock mount and the shock? Spring perch clearance & space between axle housing and spring?? I would like to use your mounts if they will fit a 32.
P.S. If you don't have a 32-34 rear end to check the fit, I have one and I could bring it up to Aledo. I'm in Morton. Call me. Jerry H has my phone number.
Steve Hayes
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 04-23-2013, 07:49 PM   #4
frederic
as long as your making shock mount studs why not make original style for the rear upper 1942-48 ford.
frederic is offline   Reply With Quote
Old 05-03-2013, 08:39 AM   #5
purehotrods
Someone already makes them and we offer them for $11 a piece.
Old 05-08-2013, 01:23 PM   #6
frederic
who makes them and where can i get some pics
frederic
[email protected]
Old 05-11-2013, 12:27 AM   #7
mike42
mike42's Avatar
Anything for a 1940 Ford ?
Thx.....Mike
mike42 is offline   Reply With Quote
Old 05-16-2013, 02:10 PM   #8
purehotrods
These are a bolt on for a 40 Ford
Old 08-20-2013, 05:17 AM   #9
wadsies1
Does your shock kit fit in
1. a 32 coupe with with a orignal rear end ?
2. a 32 coupe with a 40 rear end ?
P M sent as well
email [email protected] thanks Bruce
wadsies1 is offline   Reply With Quote
Old 09-06-2013, 09:33 PM   #10
Youthaintaftn
What does btt mean?
Youthaintaftn is offline   Reply With Quote
Old 05-08-2017, 07:35 AM   #11
purehotrods
back to the top
Old 08-19-2018, 03:14 PM   #12
purehotrods
Btt
Old 01-17-2019, 09:00 AM   #13
purehotrods
Btt
Old 04-26-2019, 09:49 PM   #14
purehotrods
Btt
