I just bought a fuel regulator from Macs. The add said made in USA the box says made in Korea and the directions are for an electric fuel pump.
Now I realize I have bad eyesight so I ass-u-me the regulator is made in the USA but the box is made in Korea. Right or am I missing something. Nice looking Holley regulator, one input and two outlets?? |
Your eyes are not fooling you. My Holley fuel reg says Korea right on it.
Must be Koreatown in LA
Unfortunately many well-known old time USA companies, who at one time made their products in the U.S., are now sending most of their manufacturing off shore. However, the seller of the product (who is not the manufacturer - in your case Mac's) isn't notified, and as far as they know, they think they are selling USA made products. Their ad copy and catalogs are still saying "Made in USA" and they either are not yet aware of the change, or haven't had time to change their catalog copy. Catalogs take months to prepare and publish, and even web sites take time to make changes. At one time it was a serious thing to misrepresent the country of origin. Now no one seems to care. As consumers we no longer have many options - how sad.
Fritz |
Does your Korean Holley regulator work, Ron? I've used those whenever I need a regulator, and thought I had figured out which one to buy!
You got an electric pump?
Flatheads forever, JD is my name. |
Theres nothing wrong with original usa made pumps that are rebuilt with quality usa parts by a few small time rebuilders on here.Charlie NY on here is one of them among a few others. ken ct.
I picked up a Holley reg. also. I have not installed it yet. I put a gauge in one of the outlets. I think (?) the 2 holes on either side of the inlet can be tapped to attach to a bracket. I plan to mount this before my mechanical pump. The electric pump is only used occasionally. I know the electric pump pressure will blow by the float needle valve. Any comments/advice? Thanks
John
I know we're getting off track here, but I'm running an Offy regulator. It's in line right after the fuel pump with a gauge T'd off it, essentially the same as OldFord2 has posted. Relying on the gauge I've been able to regulate my fuel pressure to keep my 94's from seeping. One word of warning: The rubber hose I had running from the fuel pump to the carbs was less than 6 months old. When working on the carbs, I fired the engine up only to see a constant high velocity stream of gas shooting out of hose and onto the engine. The hose was not excessively bent or kinked. My only answer is that c%&# they sell us for gas these days with all the alcohol in it had rotted the hose that quickly. I'm running all high pressure fuel injection hose for ethanol now.
P.S. I also have an electric pump in line for priming the pump. As I'm getting things sorted out I'm finding it unneccessary. |
I had an interesting problem with the Holley regulator. When I installed it, I had a slight leak on the pump side, and the plastic lens on the gauge got gasoline on it. I wiped it off, and it acutally ate the plastic, so the gauge was hard to read. I took it back and they didn't want to exchange it - said since I got gas on it, it was not warrantied. I don't know if this was because of the ethanol in the gas, but I was suprised to see gasoline ruin a fuel pressure regulator.
#12 | |
#13 | |
I've changed my flex lines three times since I finished the car in 2001. And they are going to put MORE corn in our gas. I can tell you where they can put their corn.....
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
#14 |
Ron and Old Ford2.....
I had a Mr. Gasket go to hell within 2 months. Leaked all over the place. Holley seems to be really good. I also added a gauge to it to keep pressure at 2.5 psi. I have a electric pump also. So far....it looks and works well. Send me your email address' and I'll send photos of how I set mine up. I have tried and tried and tried to attach photos here, but I cannot get it to work. Mike42 |
#15 | |
#16 |
Got 2 Holley regulators. First one corroded up within a few months. Been using Lucas and Sta-Bil Ethanol treatment and the 2nd one is still working after about 3 years. Knock on wood! :-)
#17 | |
You're right about the two mounting holes. Both of mine came with those holes tapped and even had a mounting bracket included in the package.
#18 | |
#19 |
I have had a Holley for 8 years now. Still no problems. Don't have the box so don't remember where it was made.
#20 |
Thanks guys, will give it a go. Let you know how it works out.
| Thread Tools | |
| Display Modes | |
