Old 04-02-2013, 08:08 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Fuel regulator
I just bought a fuel regulator from Macs. The add said made in USA the box says made in Korea and the directions are for an electric fuel pump.
Now I realize I have bad eyesight so I ass-u-me the regulator is made in the USA but the box is made in Korea. Right or am I missing something.
Nice looking Holley regulator, one input and two outlets??
Old 04-02-2013, 08:24 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Fuel regulator
Your eyes are not fooling you. My Holley fuel reg says Korea right on it.
19Fordy is online now   Reply With Quote
Old 04-02-2013, 08:25 PM   #3
4dFord/SC
4dFord/SC's Avatar
Must be Koreatown in LA
4dFord/SC is offline   Reply With Quote
Old 04-02-2013, 09:47 PM   #4
FRITZ47
FRITZ47's Avatar
Unfortunately many well-known old time USA companies, who at one time made their products in the U.S., are now sending most of their manufacturing off shore. However, the seller of the product (who is not the manufacturer - in your case Mac's) isn't notified, and as far as they know, they think they are selling USA made products. Their ad copy and catalogs are still saying "Made in USA" and they either are not yet aware of the change, or haven't had time to change their catalog copy. Catalogs take months to prepare and publish, and even web sites take time to make changes. At one time it was a serious thing to misrepresent the country of origin. Now no one seems to care. As consumers we no longer have many options - how sad.
Fritz
FRITZ47 is offline   Reply With Quote
Old 04-02-2013, 10:20 PM   #5
OldDad
OldDad's Avatar
Does your Korean Holley regulator work, Ron? I've used those whenever I need a regulator, and thought I had figured out which one to buy!
OldDad is offline   Reply With Quote
Old 04-03-2013, 08:38 AM   #6
Ol' Ron
Ol' Ron's Avatar
Just got it, hope it works the Mr Gasket didn't. Stayed at 4 lbs.
Old 04-03-2013, 08:53 AM   #7
Flathead man2
Flathead man2's Avatar
You got an electric pump?
Flatheads forever, JD is my name.
Flathead man2 is offline   Reply With Quote
Old 04-03-2013, 08:58 AM   #8
ken ct
Theres nothing wrong with original usa made pumps that are rebuilt with quality usa parts by a few small time rebuilders on here.Charlie NY on here is one of them among a few others. ken ct.
ken ct is offline   Reply With Quote
Old 04-03-2013, 09:31 AM   #9
oldford2
oldford2's Avatar
I picked up a Holley reg. also. I have not installed it yet. I put a gauge in one of the outlets. I think (?) the 2 holes on either side of the inlet can be tapped to attach to a bracket. I plan to mount this before my mechanical pump. The electric pump is only used occasionally. I know the electric pump pressure will blow by the float needle valve. Any comments/advice? Thanks
John
oldford2 is offline   Reply With Quote
Old 04-03-2013, 10:11 AM   #10
cuzncletus
cuzncletus's Avatar
I know we're getting off track here, but I'm running an Offy regulator. It's in line right after the fuel pump with a gauge T'd off it, essentially the same as OldFord2 has posted. Relying on the gauge I've been able to regulate my fuel pressure to keep my 94's from seeping. One word of warning: The rubber hose I had running from the fuel pump to the carbs was less than 6 months old. When working on the carbs, I fired the engine up only to see a constant high velocity stream of gas shooting out of hose and onto the engine. The hose was not excessively bent or kinked. My only answer is that c%&# they sell us for gas these days with all the alcohol in it had rotted the hose that quickly. I'm running all high pressure fuel injection hose for ethanol now.
P.S. I also have an electric pump in line for priming the pump. As I'm getting things sorted out I'm finding it unneccessary.
cuzncletus is offline   Reply With Quote
Old 04-03-2013, 10:51 AM   #11
kraken
kraken's Avatar
I had an interesting problem with the Holley regulator. When I installed it, I had a slight leak on the pump side, and the plastic lens on the gauge got gasoline on it. I wiped it off, and it acutally ate the plastic, so the gauge was hard to read. I took it back and they didn't want to exchange it - said since I got gas on it, it was not warrantied. I don't know if this was because of the ethanol in the gas, but I was suprised to see gasoline ruin a fuel pressure regulator.
kraken is offline   Reply With Quote
Old 04-03-2013, 11:02 AM   #12
ken ct
Smile Re: Fuel regulator
Ive been promoteing fuel inject. hose for use for a couple of yrs now,why it isn't being used is beond me??? ken ct. This corn gas eats up regular rubber fuel line for lunch. word to the wise. ken ct.
Old 04-04-2013, 10:27 PM   #13
dude
dude's Avatar
I've changed my flex lines three times since I finished the car in 2001. And they are going to put MORE corn in our gas. I can tell you where they can put their corn.....
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 04-05-2013, 01:21 AM   #14
mike42
mike42's Avatar
Ron and Old Ford2.....
I had a Mr. Gasket go to hell within 2 months. Leaked all over the place. Holley seems to be really good. I also added a gauge to it to keep pressure at 2.5 psi. I have a electric pump also. So far....it looks and works well.
Send me your email address' and I'll send photos of how I set mine up. I have tried and tried and tried to attach photos here, but I cannot get it to work.
Mike42
mike42 is offline   Reply With Quote
Old 04-05-2013, 06:19 AM   #15
19Fordy
19Fordy's Avatar
Plastic polish and patience will clear up the lense. Take a while and a lot of rubbing.
Old 04-05-2013, 06:42 AM   #16
Motorhead6
Got 2 Holley regulators. First one corroded up within a few months. Been using Lucas and Sta-Bil Ethanol treatment and the 2nd one is still working after about 3 years. Knock on wood! :-)
Motorhead6 is offline   Reply With Quote
Old 04-05-2013, 06:50 AM   #17
Motorhead6
You're right about the two mounting holes. Both of mine came with those holes tapped and even had a mounting bracket included in the package.
John
Old 04-05-2013, 02:02 PM   #18
BillM
BillM's Avatar
I wonder if you can "pull" gas through the regulator rather than "push" it with the pump connected to the inlet? Maybe it will work as there would be a slight vacuum on the outlet so the pressure differential is similar to having more pressure on the inlet.
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 04-05-2013, 06:05 PM   #19
42guy
42guy's Avatar
I have had a Holley for 8 years now. Still no problems. Don't have the box so don't remember where it was made.
42guy is offline   Reply With Quote
Old 04-05-2013, 07:16 PM   #20
Ol' Ron
Ol' Ron's Avatar
Thanks guys, will give it a go. Let you know how it works out.
