Old 04-01-2013, 12:53 AM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Ford 8" in a '36 Tudor?
I know there have been many Ford 8"'s put in the '35-'40 coupes, but am wondering about the Ford 8" offset interfering with the longer tudor driveshaft tunnel; is this going to be a problem?
36tudordeluxe is offline   Reply With Quote
Old 04-01-2013, 03:02 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Ford 8" in a '36 Tudor?
I think the floors and tunnels are the same for coupes and sedans.
Old 04-01-2013, 04:14 AM   #3
Tom Morookian
Tom Morookian's Avatar
It is going to be "close". Depending on how exact your body fits the chassis (frame), and exactly where the spring perches are set on the springs, the pinion yoke will be closer to the tunnel on one side.
On my 36 coupe, without a pannard bar, in hard right turns under acceleration the yoke would do a woodpecker by just bearely nicking the tunnel. A BMFH made the spacing just big enough to clear the yoke.
The universal joints tollerate the offset with no problem, What is critical is that the trans yoke and the differential yoke are parallel. Not usually a probem horizontally but make sure the spring perches and shackle lengths keep them aligned vertically.
Tom Morookian is offline   Reply With Quote
Old 04-01-2013, 07:26 AM   #4
36tbird
Did this set up in a '36 sedan. Could be a problem if you tried to dump the rear very low. But, a normal ride height is no problem.
36tbird is offline   Reply With Quote
Old 04-01-2013, 09:43 AM   #5
36tudordeluxe
Thanks everyone for responding, am using a CE rear end kit and have no plans at this point to lower the rear any more than what is provided with the CE kit.
Old 04-01-2013, 10:10 AM   #6
V8 Bob
V8 Bob's Avatar
I have a 9" in my '40 using a Chassis Engineering Inc. rear suspension system. The banjo is centered so the pinion is offset just under 1", but there are no floor/tunnel to the 3 1/2" drive shaft clearance issues with the axle fully bottomed against stock '40 axle bumpers. My design ride height is 3- 3 1/2" between the bumpers and axle.
Old 04-01-2013, 10:19 AM   #7
36tudordeluxe
Ordered new floor pans about 15 years ago from Bradely & I thought there was a difference in the length between coupe and sedan but can't remember for sure.
Old 04-01-2013, 11:08 AM   #8
Charlie Stephens
You might get a better response to this question on HAMB. Click on the "Hot Rods and Customs Forum" and it will take you there.
Charlie Stephens
Old 04-01-2013, 04:07 PM   #9
36tbird
The CE kit is what I used in my sedan. As I recall, I drilled new holes in the bottom plates in order to better center the axle in the center of the wheel well. Also, you may have to use shims to adjust the pinion angle.
Old 04-01-2013, 05:01 PM   #10
Ol' Ron
Ol' Ron's Avatar
Can you get 5 on 5 1/2 axles for the 8' rear. I knosw the explorer had them but they are getting hard to find.
Old 04-01-2013, 08:01 PM   #11
Randy in ca
Randy in ca's Avatar
Do all 8" rear ends have the offset pinion? I've never worked with anything but 9" ones and there were both available (either pinion yoke centered or offset 2"). I think with the 9" units, the pinions were centered if used in cars and offset if used in trucks and vans. Can you not get an 8" with centered pinion?
Randy in ca is offline   Reply With Quote
