Old 03-31-2013, 08:15 AM   #1
36tbird
Default 1937 block with '36 heads
I just acquired a '37 block, at least that is what the PO says it is and it is a 21 stud. I only got one head with it. Doing the search here, I see that I could block off the lower water outlets and install the '35/'36 lower ports with '35/'36 heads. But, I was wondering, could you like wise run the later style lower pumps and remove the pumps from a '35/'36 head and make new head outlets so the configuration would be like an 8BA? I ask because I have extra '35/'36 heads and maybe it will be tough to find another '37 head.
36tbird is offline   Reply With Quote
Old 03-31-2013, 08:48 AM   #2
DavidG
DavidG's Avatar
Default Re: 1937 block with '36 heads
'37 cylinder heads are not a particular challenge to find.
Old 03-31-2013, 09:45 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
I am thinking coolant flow/engine cooling would be best with pumps in block and '37 cast iron heads with center outlets. If this engine is going in a '35-'36 passenger car with stock radiator inlets, there is a NAPA/Gates one piece top hose available that fits perfectly.
John
Old 03-31-2013, 09:58 AM   #4
Brendan
Brendan's Avatar
How about running four water pumps...LOL
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 03-31-2013, 10:29 AM   #5
Yoyodyne
Yoyodyne's Avatar
I have good 37 heads if you need them.
Yoyodyne is offline   Reply With Quote
Old 03-31-2013, 11:05 AM   #6
flatjack9
flatjack9's Avatar
I wouldn't see a problem running like you suggested. I would look at the water holes in an 8Ba engine as a guide for what size holes that setup might require. Ypu could open up or block off holes accordingly to help optimize flow.
Old 03-31-2013, 01:19 PM   #7
36tbird
Thanks all for the suggestions. YoYo, when I confirm that this is a good block, I may be in contact with you.
I have no plans for the thing. I would like to have a 21 stud just for something different but do not have a car for it to go in right now.
The PO said he got it out of a Ford Dealership and it looks great, except for the long time dirt, grime and surface rust. There is no ridge at all on the cylinders so maybe it is a replacement engine.
Old 03-31-2013, 02:19 PM   #8
ken ct
From what ive heard 37 heads fit both sides NO rt+lft to them ??? ken ct.
ken ct is offline   Reply With Quote
Old 03-31-2013, 02:33 PM   #9
Gary Tosel
Gary Tosel's Avatar
Talk about 4 water pumps. I did not make this title quote.
Gary Tosel is offline   Reply With Quote
Old 03-31-2013, 02:41 PM   #10
Brendan
Brendan's Avatar
would that work?
Old 03-31-2013, 03:11 PM   #11
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I'm going to make one of those 4 pumpers to put in my liveing, I think thats coooool. Walt
Old 03-31-2013, 03:20 PM   #12
DavidG
DavidG's Avatar
Ken,
In theory that's correct that the right and left heads are interchangeable, but in actual practice, some '37 heads do not have the hole (just the boss) for the water temperature probe and should only be used on the right side.
Old 03-31-2013, 04:29 PM   #13
36tbird
We're treading on dangerous ground here talking about w. p.'s.
Old 03-31-2013, 09:57 PM   #14
Dave D
I have one NOS 37 aluminum head if you need it.
Dave D is offline   Reply With Quote
Old 04-01-2013, 12:14 AM   #15
G.M.
We did this for Skips 34 P/U since he's the "water pump man". We didn't notice much if any cooling improvement. We call it the "Polish tank" engine. G.M.
www.fordcollector.com
Old 04-01-2013, 07:32 AM   #16
36tbird
Wow, Dave, would love the look of an aluminum head. Like I said, once I know that the block is a good one, I'll see about acquiring the parts required for it. It came with the crank and valve system installed. So, if it winds up being something I build, I will have to get some rods. Not sure when I will get around to checking it out.
I have the Speedway pressure test set up. Will the 24 stud plates fit the 21 just leaving some blank holes? Might have to go digging through my junk to test that.
Old 04-01-2013, 07:45 AM   #17
31chevy
31chevy's Avatar
Here is a 37 block with 34 heads & block off plates same as 35 & 36 heads I believe, main advantage is radiator hose's fit like original.
31chevy is offline   Reply With Quote
Old 04-01-2013, 09:53 AM   #18
BrianCT
BrianCT's Avatar
Don't forget that most of the early heads are for flat top pistons.
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
