Do you have the small pencil filter in the shutoff valve?
I consider it a must. Without it any small flake of rust, bug, or leaf can block the exit flow. With the stand up filter screen this can't happen, unless you had more junk extrememly deep in the tank. Also do you have the original all steel fuel lines? (no rubber or plastic) The rubber and plasitc doesn't work with today's garbage gas and can block the flow. |
| Thread Tools | |
| Display Modes | |
