Old 02-24-2013, 08:12 PM   #21
bart78
bart78's Avatar
Default Re: keeping the patina
I would just leave it like it is. If you are wanting to keep it that way. It will probably be parked inside. It took a long time to get that way. I don't see it getting worse very soon.
bart78 is offline   Reply With Quote
Old 02-25-2013, 07:46 AM   #22
32forddump
32forddump's Avatar
Thanks. I think I will for now. It is the hood, and easily dealt with later. I had to do something about the running boards. There was no paint left and they looked like hell. They will be scuffed up soon enough.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 02-25-2013, 07:48 AM   #23
32forddump
32forddump's Avatar
What kind of material should I use to finish the inside of the doors and body?
Old 02-25-2013, 09:20 AM   #24
yachtsmanbill
yachtsmanbill's Avatar
If youve got panels to cover the guts, Id DOUCHE the heck out of it with rustoleum ZINC spray paint .... also called "cold galvanizing". Its really thin and will soak into cruddy corners etc. When we welded chainlink fence stuff etc at the power plant we used that on the fresh welds outside and it lasted forever. Makes for great fast dying primer too; just a little watery as mentioned above.
Ive also used it for a "dust coating" on cleaned steam turbine parts parked outside during over hauls after sandblasting and the stuff didnt even discolor with frost or dew sitting on all the components. Overspray wipes off with acetone; a little more rubbing with mineral spirits. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 02-25-2013, 07:58 PM   #25
Randall
Randall's Avatar
32forddump,there is a product called Pentrol,it's in the paint section at Lowes hardware,it is used as a paint additive to elliminate brush marks,some fellows with hit n mis engines turned me on to it,easy to apply,I brushed it on my 1922,took less than a qt. very thin,try it I think you will like.
Randall
Randall is offline   Reply With Quote
Old 02-27-2013, 07:52 AM   #26
32forddump
32forddump's Avatar
Thanks, I will stop by lowes today and check it out.
Old 03-07-2013, 06:05 AM   #27
32forddump
32forddump's Avatar
Wheels and axles back under car. and I have started making wood for body. Wont be long now, I hope.
Old 03-07-2013, 06:28 AM   #28
yachtsmanbill
Looks about ready to sit in and play make believe (c'mon, we all do it!) Stay with it... yer almost home! ws
Old 03-07-2013, 07:42 AM   #29
32forddump
32forddump's Avatar
Iam thinking about moving the front sear back a couple of inches.Any thoughts?
