I am going to give the instument cluster in my 40 standard a face lift.Has anyone used the decal kits that are sold for the gauge faces?What is the color of the plate that goes around the gauges and where can the paint be purchased?Can the new speedometer face be installed without taking the needle off?Has anyone been here and done this? Thanks,Russell
Super Moderator
Russel, The decals are "okay" at best.The colors are not quite accurate.
However, if you can't locate NOS gauges, it is perhaps your best option. You must remove the needle from the speedometer face and the metal "faces' from each of the gauges to apply the vinyl decals. I will check (tomorrow) and post here what paint color is a good match for the cluster bezel background area.
In one of his recent sale flyers Drake was offering (“coming soon“) new gauge faces.
Iv changed them before …. nothing to it / super easy |
Russell,Getting the speedo needle off is the hardest part. Macs has the decals. I used a sandy color duplicolor rattle can for the plate. Came out beautiful. Good luck Ken
#6 | |
that way i dont have to contort this pushing 60 back that much. you should be able to get it once you see where the mounting screws are it will come right out, remove the light sockets so it will come all the way down. rich |
#7 | |
What is the paint color you recommend for cream background area? Thanks Tom. |
I went to rattlecan alley and took in the cluster to match. I used a roll of pin stripe to try to look original. It's not quite right only we know. Everyone else loves it. Guage decals were used. See the picture in my only album....
Gauge cluster looks very nice Mike.
I just did mine over the past couple of nights:
Neat job. Congratulations.
#13 |
Ctaulbert.......my '40 has a small water mark and started to take it out, but decided against it after awhile. Any secrets to know about a easy removal ?
That really looks nice ! Mike |
#14 |
Mike - I'm rewiring the car, so I was cutting most of the wiring out. The harness along the back of the dash does somewhat block a clear path of removal, but overall, it's not too hard to remove.
There are four nuts and clamps on the back side. Remove those, disconnect the wiring, and push the cluster toward the firewall. There are four metal tabs that are folded over the chrome bezel, which hold the front of the cluster together to the cluster panel. You can unfold them easily with a screwdriver, and disassemble it from there. Hope that helps. |
#15 |
Hey CT...thx. I got as far as removing two of the nuts and started looking at where this thing was going to go after I got it unbolted ! That's when I stopped. I'll look at it again in warmer weather, as your cluster looks great.
Thanks.....Mike |
#16 |
With the Chrome bezel you really only have to undo 2 of the tabs - the 2 on the top or the 2 on the bottm - the other 2 can just be loosened.
If you do not intend to go back to completely stock, there's a great thread on the HAMB regarding redoing the 40 std gauge cluster. Might just be (or a portion there of) what you are looking to do. I've started one for my 40 p-up project .... Here's the link: http://www.jalopyjournal.com/forum/s...d.php?t=676488 You might have to join the HAMB to see this thread - just do so, do a small intro, and start lurking. Many of the same folks are on here and you would be surprised how many, many of these guys really dig stockers and saving stockers .... |
#17 |
TT....
Thanks for info. I want to clean it up and leave stock, as the car is stock. There were just so many wires under there I could not figure out which way it would come out. I'll be down your way with my Wife in April staying at the Williamsburg Inn for a week. We also are going to Monticello. Thx for the link....Mike |
#18 | |
#19 |
TT..... I'll look at my schedule and let you know.
Mike |
| Thread Tools | |
| Display Modes | |
