I have what i believe is the ring and pinion components of a Ruckstell 2 speed rearend.Plus the right and left differential housing parts. Please set me straight if iam off base. I have 2 of them and want to swap it for the rest of the parts to make a complete 2 speed rearend.I have a couple of the standard rearends, so i just need the remaining parts, I put this in the swap section of Fordbarn as well.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ Last edited by 32forddump; 02-13-2013 at 08:21 PM. |
Not Ruckstell - standard Ford Model T differential.
Bummer
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
Maybe your housings are Ruxtell?? The left one will be larger in the middle & will have a hole for the shifter. The right side is a standard model T part. There are large drum & small drum versions as well. A picture will confirm this.
Jack Innes, Brooklin, Ontario |
A Snyders catalog has a blowup of a Ruckstell rear axle. They also sell a repair manual and some of the repair parts.
I have not begun the repair of mine, so have no idea of the quality of parts available. Someone else want to chime in here? |
http://www.chaffinsgarage.com/ |
No. I was just dreaming and hoping I had something cool and rare. Iam new at this T stuff and learning daily. Thanks for your help, it certainly helped to have the spare parts when I was rebuilding the rearend.
| Thread Tools | |
| Display Modes | |
